So I was doing some searching on youtube and came across this American douche's video about his BOV
Anyway check it out. I'd be pretty pissed if my BOV was working the way his does with his extra efficient twin turbo setup. BOV FAIL anyone???
Some of the comments are pretty good and he gets pretty defensive
https://www.sau.com.au/forums/topic/324649-errr-is-this-guy-for-real-real/
It does seem odd, but reading the comments the makers of the product genuinely believe the product works and the theory behind it... I'm curious as it is difficult to see past the apparent flaw in the design.
what's up is they broke their blow off valve in the design stage and decided to make it anyway. They do make filters for BOV's (Blits Super Sound had them for a while) but I think they were only there to change the sound it produced. This thing is blowing air out at idle and at wot and he says it's because of how efficient the turbo setup is. BS! This thing would play havoc on an Airflow metered setup, you'd be coughing and spluttering all over the place if you even made it out of the drive.
EDIT - Here's the link to the BOV on the manufacturers website clicky just go to products then BOV. Apart from them sounding not too sure what their BOV is exactly, it also says it will never leak boost. I guess that means aside from at idle or at WOT with an extremely efficient turbo setup :D:(;)
there is nothing wrong with what he is saying
the company had some brilliant ground breaking idea of having a BOV that opens at low load/under vaccum, from memory it was for quicker throttle response, as when you crack the throttle, the air has a much shorter inlet path to the plenum, because intercoolers and piping and the whole turbo system is a big restriction.
the guy in the video is talking about that product specifically, because it draws in air under vaccum, people like to put filters on them. but hes saying that because the bimmer turbo is so 'efficient' and flows enough air, that there is actualy no vaccum through the BOV (again, keep in mind, this is product specific).
stupid thing is, if there is no vaccum though the BOV, there is no need to use their product on that car lol. that said it will probly open if you suddenly stab the throttle. i still found it funny though
Edited by VB-
Maybe I'm just being a troll... but... "FAKE AND GAY."
yeah they see you trolling.... They Hating... lol
But seriously it is legit. Check out their website I posted the link to it earlier. seems they have figured out a way to make all the jap BOV's obsolete due to their new "better" design
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
