Well yea nothing wrong with the logic. You may not realise that your idle control valve does exactly this.. opens at idle. Similarly on some cars (supra that I know of) the idle control valve has its own filter.
Re youtube: I can't fathom why that BOV would be open on a car that is making positive pressure though, that is just boost leak. Unless it was purely for demonstration.. but a pretty retarded demonstration if he then shows the boost leak continues under load :S.
if you actually remove the plumback pipe from the std rb25 bov, it is actually open at idle just like this setup.
if you infact watch this other video, it works.
the whole point of it being open is to allow more free flowing air into the engine before boost. if you think about it as he shows you, the turbo adds an air flow "restriction" when the car is off boost thus downgrading your throttle response.
NOTE: it would only work if you have a plumback setup for the air being released from the bov to pass back through the AFM, or either plumback or non-plumback for MAP sensor ecu's.
Edited by OMY31T
    • You beat me to it, I was going to say this -  And this -  Sounds like things are coming along pretty well and your learning heaps along the way.
    • It's the same ABS unit from the old shell.  It was all just lifted and shifted.  I am looking at the BMW MK60 ABS unit as a budget upgrade, as I'm not keen on handing over 15k for a Bosch unit.
    • Bear in mind RBs tend to be pretty terrible for fuel economy and it heavily depends on driving style. In my experience with a heavy-ass turbo Stagea the 10l/100km is really just ideal conditions highway driving. Start-stop in the city is killer and it ends up being 16-19l/100km easily. I keep track of it every time I get fuel and it is never pretty. There are a few topics in the forums where people share their fuel economy if you want to get some ideas of what it can be like. I don't think it is worth that much to compare though because it depends so much on the driving.
    • R32 HICAS, so long as the CU is not itself faulty, is easy to keep working enough for the PS. Just unplug the smaller of the two loom plugs, on the CU, like I have already said about 4000 times on this forum. This works with all the stock hardware, or with a lock bar, or with a complete removal. I know, because I have done all of them. OK, actually, I never put a lock bar on because why would you put a lock bar on when you can get rid of the whole lot, including the stupid tie rod ends?
    • Join the NorCal facebook group btw, but if you can confirm it is HICAS I would install a lock bar and do the work to keep the HICAS control unit happy despite the hardware not functioning. The HICAS control unit is also responsible for speed sensitive power steering so if it's unhappy you'll get failsafe/heavy power steering. A standalone can control that power steering solenoid valve but sometimes it's just easier to stick with the factory setup. Tomei makes a little electronic module that you can install to fool the control unit. I would probably go through the effort to not use a scotch-lok and build a harness so I don't have to chop up the OEM harness. Where you could source those connectors and pins I wouldn't know at the moment though.
