Ok,
When driving after 30mins or so. Either highway or backstreets (probly more highway, strangely)
The car will heat up, according to the temp gauge.
I have an alloy radiator, with a thermo on the back. No stock clutch fan, just thermo and it runs 100% of the time.
The other crappy fan on the front of the a/c cooler is also fitted.
When i drive on the highway 80km/h or less it sits about half way..
100km/h+ it will rise.
100 it slowly rises, 110km/h it rises much faster ....
Any ideas ?..
I was thinking just the temp. switch but really not sure. I come to this thought because while on the highway and it is 3/4+ on the gauge, i put car in neutral and switch off. The turn it back on straight away (after engine stops) and the gauge is half way again.
When at 3/4 temp, and i stop the car the overflow bottle does NOT seem to be boiling or getting water pumped into it.
Had the same problem with clutch fan, which is why i went to the thermo. But still has a bloody overheat problem
I have flushed the radiator twice. fitted a thermo and it runs all the time when ignition is on. just at the higher revs it seems to heat up quicker (3200rpm or higher)
Any thoughts ?.. (was thinking of taken it to red devil radiators or somewhere.. as in take entire car there, but really tight on funds atm)
https://www.sau.com.au/forums/topic/324667-helpopinions-on-overheating-problem/
i'd start by either buying an aftermarket water temp gauge, or getting a consult cable. with the consult cable you can see what the temp is that the ecu seeing. it uses a different sensor to the dash. either of those options will allow you to see whether the problem is actually a temp issue or a sensor/gauge issue.
if it does turn out to be a heating issue then it could be caused by the thermostat ot possibly the water pump.
also i hope you aren't turning the car off while cruising along at 100kmh.
mad's advice is good. But if it were me i'd just pull the thermostat out, and go for a drive to see if that's it. If that fixes it get a definitely fit a new one as it helps your motor get up to temperature quicker, and that's important in the long term.
Thanks for fast reply.. Pulled out thermo stat.
Seems good, although i didnt take car for a drive with no thermostat installed.
I tested it with boiled water from kettle and it opend up ect..
Re-installed it and went for a run...
Im pretty sure its a blocked up radiator as its a 2nd hand one... was fitted just over a week ago (and hte problems were there from then in a way)
Whats it cost for a professinal flush/clean ?
Im located southside of Brisbane so any advice on where to take it to ? (i know its cheaper if i pull it out of the car)
Firstly, having the thermo running 100% of the time is basically defeating the purpose for having a thermo. It only needs to run when the temp gets too high - and by too high, I mean 10 or more over thermostated temp.
The general problem I have found is getting air to flow through the radiator. It is too easy for air to simply travel down the front of the radiator and out underneath the car.
Is the fan turning in the correct direction, ie pulling air through the radiator? And it probably wouldn't hurt to get the radiator cleaned and serviced, particularly as it's second hand.
Ok, played more today
Found that the alloy radio had a fair bit of crap still in it
I have removed that and put a stock one back in. With thermo attached.
Now it doesnt get above half.... Yet to test on track.
Im thinking of going back to clutchfan and shroud (i need a new shroud).
I have 2 thermo fans setup.. i done the same to my ole RX7 and that thing never ever got hot. (one on front pushing air, one on the rear sucking air)
I know it takes that little bit longer to warm up.
Anyhow, after using acid to flushout/soak the radiator(s) i found that even more brown crap came out. After a reverse-flush with garden hose that is.
Afterwards i used acid, and caustic soda (lean mixture) and then Battery acid. (advised these are the best to use by a helpful fella at Radiator shop @ Archerfield).
The acid removed quite alot of more crap. that the standard flushing wouldnt use.
thermo's are fine if set up correctly if you dont want to go back to the clutch fan on the engine. for controlling the fans use a SPAL fan-pwm fan controller to control the fans, great piece of kit costs between $250-275 depending on where you get it from, you can get them from air con wholesalers JAYAIR or any good radiator shops. Not to hard to fit good instructions. It uses pulse width modulation to control one of your fans which slowly increases fan speed from 50% to 100% from a predetermined set point that you program and if running 2 fans will start the 2nd when the high point is reached.If you have a big FMIC this can also affect the amount of airflow to the rad look at fitting a top panel where your bonnet catch is from the front bar to rad support and the same on the bottom to force air through rad air will take path of least resistance -this is a common mistake on gtr's where the front splitter is removed.
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
