From looking at the engine manual, it should be pretty close to the oil filter, just below and to the side judging by the picture...
by oil bypass filter do you mean relocating your oil filter? or something else. i would also imagine you would get a rather small flow through the hole that the pressure switch comes from... it's not really made to have oil flowing through it.
Thanks tiberis
There will be a T piece to connect a hose and the oil switch. I havent seen this yet. The bypass filter will be located up near the rhs front of the car, near the front springs
How small a hole do you think it is?
You now have me thinking and a little concerned.
The bypass filter is only designed to clean 10 % of the oil down to 1 micron.
Given your comments I can get an adapter plate to put on the existing oil filter location but it will be an extra $50.
Any idea of thread type of a standard oil filter for my skyline?
ahk, so you are going to be running 2 filters in parallel? never heard of this before but it does sound interesting.
if you only wanted a rather small flow i guess you could use it. but based on the oil pressure sensor on the CA18 engine (which is rather similar to that of the RB series) the actual fitting was no more than 1cm in diameter.
also, how are you putting the oil back into the system? are you just going to tap it up to the head somewhere or into the rocker covers? because on the normal filter, the centre hole is the return path into the engine.
yeah, i had a sandwich plate on my CA18 so i could tap in an oil temp sensor, i managed to pick mine up for $20 at a closing down sale though. might be worth looking through the for sale section on here though and see if you can find a 2nd hand one. they are more or less just a chunk of metal, so i doubt there would be much of a difference in age or condition.
and no, sorry, no idea on thread type.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
