hi guys
im currently building an r34 gtt with an rb26/30 in it. purely for street/strip duty
the car is stripped
will be seam welded thru the whole cabin, boot, around the doors and the engine bay
have mickey thompson street slicks
and around 700hp at the wheels
full weld in cage by brown davis
it currently has hsd hr racing coilovers but i want to know what i need to have for quarter mile drag racing as these coilovers are really hard better suited for drifting
it will have a fairly large brake setup at the front and just something standard size on the back so i can fit small wheels on the back.
basically
what arms/bracing will i need?
what spring/shocks/coilovers will i need?
what diff do u recomend i have a kaaz 1.5way atm but if i need to change then i will
car is manual atm but i will be building an auto for it later
all details will be greatly appreciated
thanks
julz
https://www.sau.com.au/forums/topic/324677-suspension-for-drag-racing/
hi guys
the car is stripped
basically
thanks
julz
Mate i have run 8.9 @ 159 in a r32 gtr with completly stock suspension.
For a rear wheel drive car id put some stock suspension in the front and some 2 way adustable coil overs in the back so you can adjust the bump and rebound.
Hope this helps
Paul
