Hi there Guys,
It's been a while since i have posted a question and i have done some searching through the forums but i can't seem to find what i'm looking for.
Problem -
1995 Series 1.5 Skyline RB25DET
* Issues started with low idle - and engine stalling when cold (By the way it's an automatic) Engine would stall if any load was put on it.
* Investigated timing and all timing marks line up for 15Deg
* I've had fun by doing the following - re-Gapped sparkplugs; Got a 2nd hand CAS; Got a 2nd hand AFM; Brought new plugs
I've just been playing with the car today and managed to get it firing by itself but i had to hold my hand over the AFM to restrict the flow Engine was able to idle for 3-5secs before stalling again - I repeated the process and when firing took my hand off and died -
I'm thinking in my mind the following -=-
Either I have a break in the pipe work (Intake) but when i had my hand over the AFM the pipe was sucking in and i couldn't hear any other air. Or the AFM is cactus.
Does anyone have any other thoughts -
Regards,
Ashley Neal.
https://www.sau.com.au/forums/topic/324689-r33-rb25det-15-dramas/
Check trouble codes then
check fuel pressure
The ECU did show me Code 55 - Everything OK -
The Fuel Pump is working - I disconnected the Feeder pipe and put into a bottle plenty of fuel went into the bottle - Is there a spec on how much presure should be there?
whats it like when its warm?
is it on a stock ecu?
if its always idling very low and is on a stock ecu, perhaps try to adjust the idle up a touch. theres also a mixture screw on the back of the ecu that you could fatten up a touch, that makes them run a little easier when their cold. But if you add fuel on base idle you will also want to up the idle screw.
GL
GL
Hi mate,
The car seems to be racing when warm - sitting just shy of 1000rpm - when spec say's 650+/- has a slight sputter every now and again.
The ECU is a completely sealed unit with no trimpod for adjustment. I also checked for Dry-Solder in the AFM - and everything checks out there = ECU still giving Codee 55 = All Ok.
Edited by Nissan Maaaart
id go for fuel pump.
They can throw up an array of symptoms but seem ok with prelim testing like you did.
Otherwise vacuum leak...
Thanks mate, I've checked all the Intake piping and there is no apparent air leaks - does anyone know what type of presure should be coming from the rail --
I also did some further testing and with doing the following - blocking the Intake - and allowing a small vaccum of air into the AFM - the car would start with timing retarded - engine would fire on it's own for a moment - but if i removed my hand or made the vaccum less the engine would stall --
The suction from cranking felt quiet faint - can anyone comment on this?
Thanks.
did you look at all the piping cooler etc? my freind had a problem with his for 3 weeks before finding a pin hole in the intercooler.
try changing the fuel filter as well my turbo pulsar wouldnt run and idle and it was a blocked fuel filter but it still primed etc
+1 for fuel filter...im assuming you've checked your air filter..
My mates car wasnt starting, and racing at idle, i blew out the air filter with a compressor and it ran great for another couple of days..cheap prick wouldnt spend 20$ on a new one
Righto - Still Not anywhere -
I've replaced - all clamps, enusres tight- checked Cooler for leaks - new fuel filter -
And still no go - does anyone know how much New AFM's are and where to get them -- as I got a price from a crowd and it seemed a little steep at 780$ex out of Melb.
Or does anyone on the Northside of Bris have a 3 pin (Pink Lable) AFM that is known good that i could try?
Thanks.
Try a diffrent AFM had a simular problem on a mates car, Go to a wreckers or something and you might be able to test it, also AAC valve is clean? check that as well. Do you also have a BOV? or is it stock standard?
Edited by geraus
just unplug the AFM and see if it idles
the engine will run with no AFM and should idle OK, but it wont drive very well and will rev cap at 2500RPM
if the AFM is the culprit when you unplug it, it should run to normal idle
if the AFM is NOT the culprit when you unplug it, the same problem will be present and it will stall
Hi buddy,
The vehicle wont even start - or run enough to test this theory.
I'll try the fuel line thing shortly.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
