Hi there Guys,
It's been a while since i have posted a question and i have done some searching through the forums but i can't seem to find what i'm looking for.
Problem -
1995 Series 1.5 Skyline RB25DET
* Issues started with low idle - and engine stalling when cold (By the way it's an automatic) Engine would stall if any load was put on it.
* Investigated timing and all timing marks line up for 15Deg
* I've had fun by doing the following - re-Gapped sparkplugs; Got a 2nd hand CAS; Got a 2nd hand AFM; Brought new plugs
I've just been playing with the car today and managed to get it firing by itself but i had to hold my hand over the AFM to restrict the flow Engine was able to idle for 3-5secs before stalling again - I repeated the process and when firing took my hand off and died -
I'm thinking in my mind the following -=-
Either I have a break in the pipe work (Intake) but when i had my hand over the AFM the pipe was sucking in and i couldn't hear any other air. Or the AFM is cactus.
Does anyone have any other thoughts -
Regards,
Ashley Neal.
https://www.sau.com.au/forums/topic/324689-r33-rb25det-15-dramas/
Check trouble codes then
check fuel pressure
The ECU did show me Code 55 - Everything OK -
The Fuel Pump is working - I disconnected the Feeder pipe and put into a bottle plenty of fuel went into the bottle - Is there a spec on how much presure should be there?
whats it like when its warm?
is it on a stock ecu?
if its always idling very low and is on a stock ecu, perhaps try to adjust the idle up a touch. theres also a mixture screw on the back of the ecu that you could fatten up a touch, that makes them run a little easier when their cold. But if you add fuel on base idle you will also want to up the idle screw.
GL
GL
Hi mate,
The car seems to be racing when warm - sitting just shy of 1000rpm - when spec say's 650+/- has a slight sputter every now and again.
The ECU is a completely sealed unit with no trimpod for adjustment. I also checked for Dry-Solder in the AFM - and everything checks out there = ECU still giving Codee 55 = All Ok.
Edited by Nissan Maaaart
id go for fuel pump.
They can throw up an array of symptoms but seem ok with prelim testing like you did.
Otherwise vacuum leak...
Thanks mate, I've checked all the Intake piping and there is no apparent air leaks - does anyone know what type of presure should be coming from the rail --
I also did some further testing and with doing the following - blocking the Intake - and allowing a small vaccum of air into the AFM - the car would start with timing retarded - engine would fire on it's own for a moment - but if i removed my hand or made the vaccum less the engine would stall --
The suction from cranking felt quiet faint - can anyone comment on this?
Thanks.
did you look at all the piping cooler etc? my freind had a problem with his for 3 weeks before finding a pin hole in the intercooler.
try changing the fuel filter as well my turbo pulsar wouldnt run and idle and it was a blocked fuel filter but it still primed etc
+1 for fuel filter...im assuming you've checked your air filter..
My mates car wasnt starting, and racing at idle, i blew out the air filter with a compressor and it ran great for another couple of days..cheap prick wouldnt spend 20$ on a new one
Righto - Still Not anywhere -
I've replaced - all clamps, enusres tight- checked Cooler for leaks - new fuel filter -
And still no go - does anyone know how much New AFM's are and where to get them -- as I got a price from a crowd and it seemed a little steep at 780$ex out of Melb.
Or does anyone on the Northside of Bris have a 3 pin (Pink Lable) AFM that is known good that i could try?
Thanks.
Try a diffrent AFM had a simular problem on a mates car, Go to a wreckers or something and you might be able to test it, also AAC valve is clean? check that as well. Do you also have a BOV? or is it stock standard?
Edited by geraus
just unplug the AFM and see if it idles
the engine will run with no AFM and should idle OK, but it wont drive very well and will rev cap at 2500RPM
if the AFM is the culprit when you unplug it, it should run to normal idle
if the AFM is NOT the culprit when you unplug it, the same problem will be present and it will stall
Hi buddy,
The vehicle wont even start - or run enough to test this theory.
I'll try the fuel line thing shortly.
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
