Skyline is gone and now I need to clearout some bits before the new wheels arrive.
Front and rear Nismo strut braces for R32 Skyline. Genuine items, imported from Japan by myself. Not cheap imitation crap!
Front - $150
Rear - $150
Or $280 for both
Gates Racing Timing Belt for CA
Please confirm part numbers, I did buy this for a CA18
BRAND NEW IN PACKAGING!
$100
Front Y32 Strut Brace
Imported by myself from Japan, was for a project that never came about
$100
Z32 AFM
Brought this second hand, I've never used it
Appears to be in good condition, has plug
$250
5 RB20DET injectors
These were cleaned and flow tested about 4 months ago and have since just been in storage (4 in the photo, 5th looks the same)
5 injectors, $150
3 RB26DET injectors
As per above, these have been cleaned and flow tested about 4 months ago and have been in storage
3 injectors, $100
Factory R32GTST side mount intercooler
Replaced with a front mount, comes with standard brackets
$40
GReddy catch can
Used item, worked as a catch can should
$100
All items are located in Geelong (3220) as per title. Happy to post the smaller items, buyer pays post.
PM, serious buyers only.
https://www.sau.com.au/forums/topic/324730-r32-bits-vic-geelong/
whoops sorry guys (damn work being mental!)
strut braces are still at home, buyer never showed up after multiple arrangements.
Z32 is still for sale
my number is 0409222954 for those for are seriously interested - SMS ONLY! I can call you if necessary
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
