Skyline is gone and now I need to clearout some bits before the new wheels arrive.
Front and rear Nismo strut braces for R32 Skyline. Genuine items, imported from Japan by myself. Not cheap imitation crap!
Front - $150
Rear - $150
Or $280 for both
Gates Racing Timing Belt for CA
Please confirm part numbers, I did buy this for a CA18
BRAND NEW IN PACKAGING!
$100
Front Y32 Strut Brace
Imported by myself from Japan, was for a project that never came about
$100
Z32 AFM
Brought this second hand, I've never used it
Appears to be in good condition, has plug
$250
5 RB20DET injectors
These were cleaned and flow tested about 4 months ago and have since just been in storage (4 in the photo, 5th looks the same)
5 injectors, $150
3 RB26DET injectors
As per above, these have been cleaned and flow tested about 4 months ago and have been in storage
3 injectors, $100
Factory R32GTST side mount intercooler
Replaced with a front mount, comes with standard brackets
$40
GReddy catch can
Used item, worked as a catch can should
$100
All items are located in Geelong (3220) as per title. Happy to post the smaller items, buyer pays post.
PM, serious buyers only.
https://www.sau.com.au/forums/topic/324730-r32-bits-vic-geelong/
whoops sorry guys (damn work being mental!)
strut braces are still at home, buyer never showed up after multiple arrangements.
Z32 is still for sale
my number is 0409222954 for those for are seriously interested - SMS ONLY! I can call you if necessary
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
