I had a 33 front pipe on my S1 but the rest is different. Have you got a stock set up or are you going to 80mm or bigger? I don't have a cat but you could just measure the pipe before and after the cat if you are buying a new one.
Sorry - see you are talking cat-back. Pretty sure you need a Stagea specific one or you could just get an exhaust shop to make one up.
yeah Ive currently got a 3 inch system from front to back but have a couple of holes in the mid and rear mufflers so rather than repairing them I thought replacing it with an r33 catback which are a dime a dozen would be a quick fix.
it will fit, but you need a section put in after the centre muffler, and possibly a section added after the rear diff. It will probably still be cheaper getting one modified than getting a zorst shop to make it all custom.
I've got a 33 cat back on my S2. It has had a piece probably about 10inches long added in the middle and the back box tweaked around slightly as well as the hangers moved.
I was in at an axhaust shop today and the guy told me that the X-force R33 systems require the rear hanger to be moved 8" to fit into a Stagea. He said they were a perfect fit.
I'm not convinced as the Stagea has a longer rear overhang than an R33.
+1 The 3" system on my Stagea was originally for an R33. Just added a longer section in the middle, via a Berklee resonator, and all was sweet. :)
A skyline exhaust WILL NOT be a direct fit for a C34. You need to add some piping, generally some before the resonator and some after it. A descent exhaust shop will be able to do this for you rather cheap. So IMO if your after a cheap turbo back for your stag buy a 2nd hand RB25 3" bellmouth front dump for about $100 and then wait for a catback comes up that you like. Shouldn't cost any more than $100 to mod and fit the cat back, do the dump yourself.
Heres the comparison of a stock rs4v zhorts with a R32 3 1/4" cat back
Clearly its not going to fit but hook it up and have a listen to see if you want anything of it changed while your getting piping added.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
