I had a 33 front pipe on my S1 but the rest is different. Have you got a stock set up or are you going to 80mm or bigger? I don't have a cat but you could just measure the pipe before and after the cat if you are buying a new one.
Sorry - see you are talking cat-back. Pretty sure you need a Stagea specific one or you could just get an exhaust shop to make one up.
yeah Ive currently got a 3 inch system from front to back but have a couple of holes in the mid and rear mufflers so rather than repairing them I thought replacing it with an r33 catback which are a dime a dozen would be a quick fix.
it will fit, but you need a section put in after the centre muffler, and possibly a section added after the rear diff. It will probably still be cheaper getting one modified than getting a zorst shop to make it all custom.
I've got a 33 cat back on my S2. It has had a piece probably about 10inches long added in the middle and the back box tweaked around slightly as well as the hangers moved.
I was in at an axhaust shop today and the guy told me that the X-force R33 systems require the rear hanger to be moved 8" to fit into a Stagea. He said they were a perfect fit.
I'm not convinced as the Stagea has a longer rear overhang than an R33.
+1 The 3" system on my Stagea was originally for an R33. Just added a longer section in the middle, via a Berklee resonator, and all was sweet. :)
A skyline exhaust WILL NOT be a direct fit for a C34. You need to add some piping, generally some before the resonator and some after it. A descent exhaust shop will be able to do this for you rather cheap. So IMO if your after a cheap turbo back for your stag buy a 2nd hand RB25 3" bellmouth front dump for about $100 and then wait for a catback comes up that you like. Shouldn't cost any more than $100 to mod and fit the cat back, do the dump yourself.
Heres the comparison of a stock rs4v zhorts with a R32 3 1/4" cat back
Clearly its not going to fit but hook it up and have a listen to see if you want anything of it changed while your getting piping added.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
