I have a complete RB26DETT for sale that is from an R32 GTR.
I had this in my vl but its time to cut my loses and sell up on everything - new projects in mind.
The engine has been stripped down, checked, cleaned and put back together with all new gaskets etc. Anything that needed to be replaced did.
I have detailed this engine from ground up.
The covers have been smoothed where needed and painted in clear over base custom Silver.
Lots of bits and pieces polished by a professional (Twin Turbo Pipe, fuel reg etc).
Everything else such as water lines have been hand polished.
Nuts and bolts have been replaced with all brand new stainless steel.
I no longer have the GTR sump, I have a modified sump to make it rear wheel drive only - so this will suit anyone with a GTST
The engine comes complete. Turbos are perfect etc. I can chuck in the board of a Mines ECU to go with it, which can go into your ECU casing.
I have an R32 GTR style intercooler than you can have for an extra $200 - can supply photos if needed. Its painted the same colour as the engine covers.
The engine is completely stock, but everything is in perfect working order. As stated above its all been checked, cleaned and run and tested. As you can see there is a lot of hours spent getting this to look a show piece.
Engine is located in Eastern Suburbs of Melbourne, inspections more than welcome.
If you have any questions do not hesitate to contact me on 0419 387 858
Im sure I have left out some info so if I have, just let me know.
https://www.sau.com.au/forums/topic/324792-r32-gtr-rb26dett-engine-5200-ono/
