Alpinestars Ice Leather Jacket - Black. Got a dirt bike instead. Used once $500
49cc Pocketbike painted matte black. Needs some TLC. Some surface rust from sitting around. Fresh fuel and a spark plug should see it going good again. $100
Located on the gold coast, jacket can be posted at buyers expense
Edited by Jum
https://www.sau.com.au/forums/topic/324800-alpinestars-jacket-pocket-bike/
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
