Hi guys,
          Having trouble the last couple of weeks with my r33 s2. When cold runs fine no probs but I drive for about 5 mins or so and car bogs down on acceleration almost to the point of putting my head through the windscreen then taking off then bogging, making me look like an absolute tard. When I come to a stop, the idle will fluctuate from 100 to 1500rpm, up and down, up and down car shaking a little, sometimes blows a little white smoke, just a puff. It started of only slightly, now its at the point that it cannot be driven warm. I've cleaned the afm, aac and still the problem exists. My only guess is the 02 sensor, as it runs great when cold.
Any suggestions would be great
thx steve
https://www.sau.com.au/forums/topic/324812-power-and-idle-issue-when-warm/
I think i might have a similar problem with my mates car, is it like this:
This is the first video. In this video i had just started the car, so this video shows what the car does when it is cold:
Now this is the second video. This was about after 1 minute of driving, notice the revs at the very start of the video... Then i accelerate a bit and you can clearly see that the car drives fine all the way to redline:
This third video is after about 3 minutes of driving. When it goes to about 3.5k rpm is when i changed into 3rd gear to show you that the car drives fine when decelerating. Then i turn a corner and accelerate to 4k rpm, car still drives fine then. After about 0.37 seconds into the video is when you need to turn the volume up a bit to hear the engine. Notice how it lurches? That is the car, not me:
This is the 4th video, after about 5 minutes of driving, i had got back to my house and was sitting in the driveway. This is how it idles after just a quick 5 minute drive:
So just to summarize, car idles fine when first started (was a little bit rough initially, but after about 5 seconds it came right and sat at 1.5k rpm which is when i started filming). But then while driving the car lurches if you have the throttle slightly open to cruise. Decelerating is fine, doesn't lurch at all. Acceleration is fine, doesn't lurch at all. But if you sit on the throttle a little bit just to maintain your speed, then the car lurches like in the 3rd video.
Same sort of problem? If so, anyone able to help us, I'm so stumped by this problem. Same boat, have replaced the AAC valve, cleaned AFM, tried unplugging AFM but it runs much worse, have checked for vacuum leaks but found nothing... Car is a completely stock R32 GTST except for 3" turbo back exhaust, pod filter, and alloy radiator.
Spot on.. same thing
Had the same issue with my gtr, turned out the harness had a brake in it to the air flow meter.
Can also be because the air flow meters are only soldered in the meter itself and the terminals break off over time with bumps etc
If you got the standard computer, use the pin out to flash codes and see if there are any air flow meter related or others there. This is how I found mine.
With an after market computer, plug in or use the hand reader if you can to check air flow meter voltage, it should always be between 0.5v to 4.5v inorder to be working properly. Get someone to check this while you drive to see if thats the problem.
Hope this helps, cause i know how gay this is when your driving. I broke down on a mountain and took my brother 5hrs to get to me and a chick that I had only just started seeing lol and this was after a big night out and been tired and hung over. Lets just say she wasn't impressed haha
Matt
Yeh that's why we don't want to take it to a workshop, anyone that can use CONSULT is a good 40 minute drive from where we are, the car drives like shit after 2 minutes :)
Edited by Hanaldo
why don't you just flash the codes yourself? It is exactly the same as taking it to a mechanic with a consult only that they can see it in real time. But if the issue already exists then it would be stored in the ecm and flash out as a code. At least then you would have some idea of what is happening.
Normally jerking and then going is a sign of the engine been far to lean.
Some one with a manual would be able to tell you how to flash the codes and what each code means. Its not hard to do.
maybe clean the AAc valve, I had a similar problem and this fixed it. there is a diy thread on there about it
Have cleaned the old one, didn't work so replaced it with a new one and it still did nothing :glare:
Lol now to find someone that knows how to do that
Ok, well i've solved my problem. The cold idle control valve (not sure if that is the correct terminology, but that is what it does) is stuck open, which is why the car runs fine when it is cold (albeit idling quite high), but then as it gets warm the engine is getting too much air and it starts driving like crap. So it is pretty much a vacuum leak.
Steve, in case this solves your problem as well I'll try to go into a bit more detail so you can check it out. Just to clarify, the cold idle control valve is not the ACC idle control valve, but it is near it. You will see on the ACC valve that it has the vacuum hose coming off it yeh? That vacuum hose joins onto two other hoses with a T-Piece. The bottom hose is the one you want, follow it down and it leads to the cold idle control valve which is located near the throttle body. Doesn't look like much, it is just a sort of metal plate where the hose joins onto. This valve has a metal disc that opens when it is cold, and is meant to close when it is warm, but for some reason on my mates car it is stuck open and won't shut.
We have blocked off the bottom connector of the T-piece and the hose leading to the idle control valve (really need to block it off well because it easily becomes unstuck when you hit boost), and this has solved the problems, although it will now be a bit rough when it is cold. Otherwise it drives perfect again.
Edited by Hanaldo
thanks mate, id definately give it a go and let u know
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
