Ok, well i've solved my problem. The cold idle control valve (not sure if that is the correct terminology, but that is what it does) is stuck open, which is why the car runs fine when it is cold (albeit idling quite high), but then as it gets warm the engine is getting too much air and it starts driving like crap. So it is pretty much a vacuum leak.
Steve, in case this solves your problem as well I'll try to go into a bit more detail so you can check it out. Just to clarify, the cold idle control valve is not the ACC idle control valve, but it is near it. You will see on the ACC valve that it has the vacuum hose coming off it yeh? That vacuum hose joins onto two other hoses with a T-Piece. The bottom hose is the one you want, follow it down and it leads to the cold idle control valve which is located near the throttle body. Doesn't look like much, it is just a sort of metal plate where the hose joins onto. This valve has a metal disc that opens when it is cold, and is meant to close when it is warm, but for some reason on my mates car it is stuck open and won't shut.
We have blocked off the bottom connector of the T-piece and the hose leading to the idle control valve (really need to block it off well because it easily becomes unstuck when you hit boost), and this has solved the problems, although it will now be a bit rough when it is cold. Otherwise it drives perfect again.
Thanks for the post mate, but there is no chance of getting this off in an r33 without taking the plenum chamber off from what i can see. Iv'e tried for two days now with no hope. I actually let the car warm up until it started to idle rough then clamped the hose, this didn't do anything at all, so i'm stumped. I'll just take it to an auto elect when I get a chance. Thanks for your help though.
Cheers Steve.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
