hey guys,
i recently bought a turbo tech manual boost controller off ebay, and loosened the screw all the way (0.7bar), however when i have the boost controller installed, my car develops a big misfire...
Is there any obvious cause for this?
mods: bosch 040, turboback exhaust, pod
https://www.sau.com.au/forums/topic/324825-t-piece-boost-controller/
I would say 10 PSI and no tune = BAD
Restrictive exhaust would not help and the manual boost controllers are known to spike so could be way more boost and leaning out. (Not a big fan, better to use electric one)
You realy need a tune before you do damage.
You pretty much answered the question yourself "missfire". A missfire is a poor spark, so either your spark plugs need replacing or your 15 year old coilpacks aren't up to the job anymore, or both.
Edited by PM-R33
it wont be running lean. more boost sends things rather rich with the stock ecu and turbo.
as PM-33 said, poor spark. i'm assuming its under full load around 4500-600rpm? if so the most likely culprit are tired coilpacks. can try taping/siliconing them or get new ones. in the meantime you can gap your plugs down a bit.
have a search around here, theres countless threads on this
hey guys thanks for the replies,
i have recently just replaced my spark plugs gapped to 108mm, i sussed out the coil packs and there are no visible hairline cracks etc.. in them.
With the stock boost solenoid, with the exhaust my car runs 7psi <4500rpm, then above 4500rpm it goes to 10psi... and starts to 'misfire' when its on 10psi.
also cleaned the A/F meter, replaced the fuel filter, air filter and reset the ECU.
Edited by shaun123
the coils may look ok, but may not be ok. try taping them up with electrical tape and see if that helps at all, but my guess is that you'll be up for new coils.
Leave your coil covers off and run the engine at night in the dark.
Enjoy the electrical storm.
Id be testing plugs regapped to 0.8mm first though, before you put the coil covers on have a look for sparks arcing around the coil packs.
I also run a smear of dielectric grease on the ends of my coil packs to help stop spark loss on both my GTR and XR6.
had the same issue.
Fixed by gapping the plugs to 0.8. Also smeared a thin layer of high-temp silicone gasket-making crap around the square block part of each coilpack (theres a thread somewhere in the DIY section), since I had them out anyway.
gap plugs then put it in 5th gear at 50kph then floor it. if it missfires then it will missfire badly under this load and its gona be your coilpack. just spend about $250 bucks on a set of heavy duty dsr coils. they are some of the best
This sounds like an excessively bad way to diagnose the issues sure it might work but the strain on the motor/gearbox would be stupid. 50kph in 5th and full throttle lol
Its actully what the mechanics do to try help diagnose the problem. Probly the least stressfull on the engine as well. How would it be more of a strain at 1500 rpm then at 4500 rpm? Takes you about a second to find out how badly its missfiring. And then you can fix it. Unless you want to continously thrash your car finding out how badly its missfiring. And pretty sure it wouldnt have a problem with the gearbox. How would it?
heavy duty dsr coils? what are these? (other than a crapload cheaper than splitfires and yellow jackets)
I got them off trademe coz im in NZ and my mate has them in his 25det gts4. My engine runs absolutely perfect and i wouldnt have anything else to be honest. Nothing is going to out perform them for how much power i have. PLus they are like 400 bucks cheaper then yellow jacket and stuff lol
no, you are correct. stock turbo @ 10psi on stock ecu is fine 99% of the time. there will be the odd car that will hit rich and retard at this level, but very few, and this can come down to innacuracy of the boost gauge (may be reading 10psi but the car is actually boosting 11 or 12psi)
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
