gtr r32 r-h guard $150
r34 fight guard $150
r32 sedan rear bar $50
front calipers and rotors r32 gtst $200 for the pair
r32 gtr rb26 5 speed gearbox $650
hicas lock bar $70
r33 nismo shocks and springs set of four front and rear $250
tommy k fibreglass front bar r33 series 1 $100
genuine bn rear bar r33 coupe $100
r33 front hubs no brakes $50 each
genuine r33 gtr rear strut brace $75
apexi frotn strut brace r33 $75
r33 coupe boot lid without spoiler no holes gun metal grey $75
r32 gtst pai of front seats $50 drivers seat is average
r33 auto tailshaft $50
s13 silvia left headlight 3 round projectors $100
s13 silvia right hand headlight 2 round projectors $70
r33 front bar m sports style brand un unpainted $50
r33 front steering rack complete $100
r33 rear diff lsd 4.1 $200
r32 gtst headlight left $100
r32 gtst headlight right $100
rb20 turbo charger $250
standard neo6 coilpacks,
rb20 starter motor,
various rb crank angle sensor and ignitor modules
r33 coupe rh window reg motor $75
stock neo rb25 camshafts 40,000kms old $200
rb26 ecu $150 (think it has some kid of chip, will find out more for any 1 interested)
Rb20 cylinder head shaved and vac tested ready to go $450
I have most front suspension parts and x'member for r33, i have most rear suspensions and x'member for r32
Most interior parts available for r33 coupe s1 dash, console, carpets trims etc.i wrecked a r33 coupe so have windscreens, quater glasses, most parts.
If theres any odds and ends you need for r33 or r32 let me know cos i may have it lying around.
If you want pics of anything im happy to send some to you, just ask. also happy to freight parts.
Edited by neo633
hey mate will the r33 gtr rear strut brace fit an r33 gtst?
Hey Mate, yes they do fit into the gtst, i had it in my gtst. they mount to the two threaded studs that come off the side of the rear strut towers.
Wont go into a sedan but is fine for any coupe as far as im aware.
hi just wondering if the r33 nismo shocks and springs are adjustable and if you have any picks? do they fit series 2 also?
They are damper adjustable not height adjust, they will fit into a series 2 no dramas. pm me your email addy if you dont mind
or email me on neo6@live.com.au
Thanks,
Nick
  • 4 weeks later...
  • 3 weeks later...
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
