Hey guys, Ive been thinking about getting a pod filter but only thing that stopped me from getting one was cutting hole through the body for cai.
I was wondering if anyone tried leaving the stock air vent and cut the box out. if you know what i mean.
and cover the pod with home made heatshield?
I've attached a pic here. So cut where the red dot is, and remove the panel filter box and pod goes there. and make a heat shield on top.
Is this possible? will there be enough space for pod to fit in there?
Thanks guys.
thats exactly what i did, after i installed a pod filter, i cut the factory snorkle off in a half circle shape so that it rams air right down on top of the pod then built a heat shield for it - still myt make one comming up from underneath too tho - lots of room for it all to work out, comes out looking pretty good too
o wow that looks neat!
do u mind telling me what parts i need to buy to get set up like yours?
never done any work inside my engine bay so im alil lost lol
tbh i dont even know how to take the air box out haha
its all really easy, once you get the airbox unbolted you just need a muffler shop to bend up a piece of pipe for the intake, they should know what to do, and then once you get your pod all in place you just have to chop off the snorkle from the air box with a big wood saw, then use a smaller wood saw (like a couping saw) to shape a curve into the cut so it lines up nice and flush with the pod, you'll have to cut it closer and closer by test fitting it over and over till you have cut away just enough for it all to sit right
but lots of people on here reckon a hi flow panel filter is better and alot less work, your choice
try doing a search - lots of people on here have already asked and answered heaps of questions on pod filters and how to install them and all the pros and cons
too late for panel filter now, ive already bought apexi power intake :D
for now i only took the top part of the airbox out, vac line just hanging there.
i guess ill have to go around search for some piping then.. so it reaches under the vent.
thanks mann
oh look what i found
http://www.skylinesaustralia.com/forums/In...;hl=intake+pipe
only just found it haha.
looks like i dont need whole new piping, just L shaped pipe to extend it. how exciting lol
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
