Hi rob and welcome to SAU. A few little details. Please ALWAYS use the search function (top right corner of the page) and see if your topic has been covered before. In almost all cases it has. Please DO NOT just make up new topics willy, nilly - we have enough trouble with important information topics being kicked off the front page in no time for the forums to be filled with redundant threads that have been answered before.
So, I suggest you go do a search and check the stickied 'workshop information' thread in the sticked thread section at the top of the SA forum.
i had my alarm installed by GT Autosound......they did an awesome work.....also had dealings with Auto Perfection and loved the service and quality of work from there too mate.....how far down south are you talking and if your willing to drive up a bit north as well :D
or save money....get a viper alarm and you wont regret it.....loads of functions and pretty cheap as well......then get it installed :P
Also one of the easiest alarms to get past if you know what youre doing :D
But in saying that, no alarm is good enough to stop someone from taking your car that knows what theyre doing anyways...
Edited by SkyHi_33
if someone is going to take my car then they are going to do whatever it takes to get it......regardless of what i do mate.....but a viper is a good enough investment for me
Also probably a good idea to not let people know what alarm you have ;P
I know its unlikely that any SAU member will be considering stealing a car but even car crims in lizbef have net access nowadays
-D
Troy you don't even need an alarm to be covered by insurance unless they absolutely made it clear that they wouldn't insure you without one.......if that was the case, they would tell you exactly what to install.
Having said that, best to always air on the side of caution and check with your insurance company as Troy stated....it's only a phone call.
I have no problem whatsoever with a dirty big blue VIPER symbol flashing on my dash window .... and it would seem the crooks do respect it, as I haven't had anyone touch my car (except for one small testing incident) and I park it everywhere. They also don't know it is the black wired version, I have 2 kill switches, and I have 4 of the loudest piezo screamers you have ever heard .... if their ears can take 30-90 seconds of those things going off in their ears while they hotwire the car, then they can have it.
well I've had Just Cars and Shannons and they both require alarms with proper immobilization points for agree coverage on my car
in case you want a real scare on car theft go here
CARSAFE theft stats per car
good old Adelaide, at least they can come first at something..lol
they must meet these regulations
AS/NZS 4601:1999 certified system include:
➜ Automatic immobilisation within 40 seconds
of ignition switch off;
➜ 2 independent points of immobilisation;
➜ Connections enclosed in security housing;
➜ All black security wiring;
➜ Flashing dashboard LED to indicate that the system
is armed; and
➜ Secure owner PIN override.
the alarm is only as good as the install, and the 100% use of it, even when it's in your garage
and there isn't any alarms that can't be cracked by a pro. if they want your car it's gone.
but it will prevent 95% of the other idiots from taking your car
multi layer security is best and common sense, don't leave your car in the hood..lol
Lol:
YOUR POSTCODE
With 5 or more thefts reported each week, postcode 5108 is one of the highest theft risk locations. We recommend that you read these simple precautions you can take to protect your vehicle from theft.
YOUR CAR
The NISSAN SKYLINE 1998 was not fitted with an immobiliser when it was manufactured and unless it has been fitted with an Australian Standards approved immobiliser since then it is at risk of theft.
New passenger cars sold in Australia are required to have an immobiliser but before 2001 many cars weren't fitted with them. As a result these cars are targets for opportunists to 'hotwire' using something as simple as a screwdriver.
Engine immobilisers provide the most effective barrier available between a thief and your car, as long as you keep your keys safe. Click here for more information.
I am with Just Cars Troy and all they wanted was any alarm with 2 point immobilisation. The original version of my alarm didn't come with black wiring and they didn't give a toss about it when I told them. I even gave them my alarm model number and they looked it up and said it was fine.
so what does an insurance company do when it comes to a pay out if the car is never recovered or burnt to the ground (unable to confirm proper alarm installation if any)........they payout regardless of policy
Well respected insurance companies - such as Shannons - specify a particular standard of alarm system (as per AS/NZS certification) and required documentation to prove installation by an accredited installer - I have both documents noted on my Shannons policy. As for insurance companies such as JC... if one doesn't have anything nice to say, best not to say anything at all.
When I crashed my S15 (my fault) JC were awesome in letting me choose repairer, varying the amount of work done (I added a fg bodykit in leiu of the standard bars they had allowed for). I really can't complain at all.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
