Hi guys,
Unfortunately I have had an electronic failure within my car, I believe it was one of the Airflow meters, which has caused pistons 4,5 and 6 to lean out and die.
This is due to the fact that the standard computer runs the motor as two bank of 3 cylinders and each A/F meter controls one bank of 3 cylinders each.
Unfortunately I can't afford the rebuild and am looking at having a break from cars for a while.
I am the only owner this car has had in Australia since it's purchase in September last year. When I bought the car it was in completely standard and original condition. It has always been garaged and I have always taken great care of her.
Photo's here: Shauns GTR
Details:
10/92 Build.
White in colour.
75,000 k's.
Serviced every 5,000k's using full synthetic oil.
Just had Front Diff, Rear Diff, Gearbox and Transfer case fluids changed and also had the 4WD system bled.
Mods:
Koni adjustable shocks (1 week old)
Eibach Springs (1 week old)
Trust MX front pipes (1 month old).
Hi Flow 3" cat (1 month old).
HKS Hiper cat back exhaust (brand new).
HKS Cam Gears (1 month old).
Trust Airinx Filter Kit.
Trust Alloy Gear knob.
Trust Alloy Oil Filler Cap.
Trust Alloy Radiator Cap.
Trust White Faced Boost Gauge.
Ultra Turbo Timer.
Original Nismo N1 Intercooler Vents (not fitted yet)
Exxedy Deiken Heavy Duty 3 Puck Single Plate Clutch (8 months old).
EBC Green Stuff Front pads (3 months old).
EBC Brake Fluid - Full Flush (3 months old).
New Front Bushes.
The car was dynoed recently on a Dyno Dynamics rear wheel drive dyno (Race Pace Motorsport) and achieved 240rwkw.
I ran it at Heathcote and managed an 11.57 @ 118mph down the quarter.
I still have all the original parts including Exhaust, Airbox etc. and would consider selling it in standard form if necessary. If bought as is you will get all the standard parts too.
If you are prepared to spend the money to rebuild the car properley, it will be very fast and reliable. I can put you in touch with a very reputable engine builder for this job.
I am looking for interest around the $29,500 mark, please ring me to discuss this if you are interested.
Any reasonable offer considered
Thanks,
Shaun.
0411 753 501
[email protected] Nightime home email
[email protected] Daytime work email
https://www.sau.com.au/forums/topic/3249-r32-gtr-with-damaged-engine/
I can't really afford the rebuild and would like a break from the car scene for a while.
If anyone is interested in the car, I can also source them a set of low kilometer, good condition HKS GT2530's at a good price.
These would be perfect to bolt to the side of a freshly built RB26.
Shaun.
Any offers??
I am flexible with the price.
I can organise a full rebuild with oversized pistons etc. for around the $4,000 to $5,000 mark. Once rebuilt you will end up with a very fast and very reliable car for a very reasonable price.
Anyone interested in the HKS2530's - CLICK HERE
OK Guys,
Here's the deal. I am going to give it until next weekend to try and sell the car as it is.
If I still have had no luck by then, I will be putting a new motor in it and selling it as an 11 second GTR, running and complete.
For anyone that is looking at buying the car as it is, I can help them get it back up and running or you can take care of this your self.
I can suggest a couple of options for anyone who may be interested in the car but is unsure of the cost involved in getting it on the road again.
OPTION 1 (used engine):
I can get you in touch with someone who has a used RB26 in good condition for $5,000. You can put this motor in the car and then sell the damaged RB26 that comes out of it.
OPTION 2 (rebuilt engine):
I spoke with SUBZERO in Queensland and they will do a swap on the damaged RB26 for a freshly rebuilt RB26 for $5,500. The new engine is an R33 RB26 fully rebuilt with all new parts, including Racing Spec Rings and Bearings.
I am preppared to sell the car as it is with the damaged engine for $28,000 FIRM or I can take all the aftermarket parts off the car and return it to stock standard form and then I would want $25,000 FIRM.
Thanks,
Shaun.
(contact details in first post at start of thread)
Shaun,
Just a word of warning useing R33 engine in R32 GTR.
If only it was that easy, i thought oh year stuff all difference but even things like the heater return hoses have different sizes, not to mention the issues with power steer pumps etc.
Sure it can be done no worries, just may take a bit longer than you expect, best way is get an R33 long motor and bolt up all the accessorys off r32 motor and then i think its only 1 or 2 things that cause any problems.
E
Thanks for the advice Evan.
I spoke to Subzero about this and they also know of this. They actually use all my bits and piecs and bolt them all up to the R33 Block and Head.
Thanks,
Shaun.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
