Hey Guys,
Sorry for the basic question, I did a search and everyone assumes they know where the horn is.
When I press my horn it makes a really strange dull noise. Therefore, I would like to replace the horn as it seems like its getting power etc.
Where do I find the horn on my R34 GT-T?
https://www.sau.com.au/forums/topic/324931-where-is-the-horn-on-an-r34-gt-t/
you need to be unlucky like me...
someone changed the horn on my R33 and the ones he replaced them with are white and they stand out like dogs balls on a black car when looking at the front >.<
but yeah, should be able to see them through the front grill type bit. usually not bigger than the size of your hand. could also have 2.
You know you can relocate the horn very easily, they are usually held in with a single bolt and there's more than one mounting location on the radiator/radiator support. Or maybe I'm thinking of my alarm.
yeah, i know i can. just haven't had time to do it yet. (haven't even had a chance to give it a wash since i bought it)
i was also contemplating buying a crappy $2 can of black paint and just taking them off and spraying them. even if the paint job aint that good, they will be less noticeable.
but it's on my list of things to do after:
- 3-stage boost controller using stock solenoid and less than $10 of parts.
- removing central locking security flaw.
- having doors unlock when car is on and handbrake is pulled.
- wash car :glare:
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
