You said you would trade for a track car? Running or a project track car and cash? I have an rx7 set up for track work, needs motor box, ecu but the rest of its there. Was planning on fitting the running gear from my other car into it but im selling it all up.
Giulian
You still got this, & are you interested in swaps for a slightly more showy R32 GTS-T??
http://www.skylinesaustralia.com/forums/R3...-N-t323449.html
Can supply with extra parts & could be used for a track car, although i just put 12 months rego on it as its been my daily driver for nearly 3 years....
