Question- does an r33 gtr water pump fit an r32 gtr, if not, what is the best way to check if the engine is a 33gtr or 32gtr?
cheers
ps.
ALL THE BS
my brother bought an r32 gtr from a mate who put a new engine in it, the wrekers told him it was a 33gtr engine.
We had to put a new water pump in it and bought one for 33gtr, low and behold it leaks.
Guy we bought it off says it must be 32 engine because water pumps are different
Water pump is the same on all RB26 engines regardless of model. If it is leaking a small dribble from the snout on the front of the pump the seal will be stuffed. I would not reccomend useing a second hand water pump as a brnd new N1 pump is only around $280.00 dollars or so
Mate there is somthing up with whoever you have bought the pump through, But can garentee that the water pump is the same on all RB26 engines regardless of model mate. Maybe the supplier marks the pumps they sell with their own part no or somthing.
That is incorrect.
I purchased a N1 water pump for my rb26 and it leaked due to a slot being where one of the bolt holes should have been. Which was what made it leak. I have heard of people welding the slot up and then re drilling the bolt hole.
A far as im aware, the r32 rb26 water pump is different to 33 and 34. Well thats with the N1 range anyway. I ended up selling the water pump to a member on here with a 34 and he had no problems..
yeh the dude reckons that there is a slight difference therefore r32 requires welding, well great to know $200 later in labour!
might wanna sticky this because its proven, that r32 is different from 33 or 34 waterpump therefore requires some sort of adjustment ie by welding
closed
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
