Hi guys..
I have a weird problem, every now and then ONLY IN THE MORNING will happen once every month at least.... or maby 2 times..
My car on cold start up... will fire up but only run 5 cylinders... now ill drive it running like fkn shit all the way to work... (7:45 am )
by 5:30 6ish PM i will then go back to my car start it up and drive home on 6 cylinders.. running sweet....
problem is... i cant diagnose since i gotta go to work and at work im to busy to look at it myself... (apprentice mech)
Things to know
Recent Yellow jacket coil packs brand new
Recent Iridium plugs x6
things remaining old are the loom to the coil packs and the ignition moduel.
If any one has had this problem remember its only in the morning when the car has been sitting for ages.. in the cold also..
any help will be greatly appreciated :glare:
https://www.sau.com.au/forums/topic/324980-r32-rb20-gts-4/
Can some professionals with experience in these awkward missfire problems help me ? im fkn doped at whats happening it only does it in the morning after a 10 min drive it sits at the carpark all day then after work its fine.... every day ....????? Help! ?
https://www.sau.com.au/forums/topic/324980-r32-rb20-gts-4/#findComment-5304918
it may be moisute getting into the plugs on the look. try some electrical contact cleaner or some of the electrical paste you can get on all the plugs to try and improve the connection.
if you have the coil pack valley cover on then try removing it and leave it off for a few days and see what happens.
https://www.sau.com.au/forums/topic/324980-r32-rb20-gts-4/#findComment-5305707
id say its moisture to. but seems like a massive amount of moisture getting in... when i cleaned my engine bay (with a shitload of water) the engine ran ruff as guts, but even after 10 mins it was fine of driving, so i dont know how a little bit of moisture getting into your plugs and not drying after getting to work, which i assume is 30 mins away? and not have it dry up...
just a thought, could it be oil leaking into the plugs? check your valley covers
https://www.sau.com.au/forums/topic/324980-r32-rb20-gts-4/#findComment-5305941
coil packs are new yellojackets but it was doing it b4 i changed them too.. the center cover is off..... 1 question the ignition module at the back which way does the arrow on the top plastic face... its not dummy proof maby i put it on the wrong way ? but the moisture problem is 100% i drove it for 1 hr yesterday running shit then BAM all 6 started fireing properly... its gota be a shit connection someware.... ill try contact cleaner..
https://www.sau.com.au/forums/topic/324980-r32-rb20-gts-4/#findComment-5307325
the loom connectors look good...no sign of shitty connection... the wires all the way back rnt 100% perfect but i duno i dont wana go buying shit for nothing... maby grab a multy meter n test? can this be done?
https://www.sau.com.au/forums/topic/324980-r32-rb20-gts-4/#findComment-5309256
It would be a good idea to test the igniter and coil plug in the morning by contact cleaning the coil plug then start it up and check. If it still runs shit clean the igniter plug, start it and doing this in the morning will ensure you've gotten rid of the moisture.
It only needs a small spray on the plug and pins to evaporate any moisture, just give the cleaner 20 seconds to fully evaporate before you plug it back in.
https://www.sau.com.au/forums/topic/324980-r32-rb20-gts-4/#findComment-5309562
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
