well i have (had) a rb25det s2..
gt3076r .82 @16psi
38mm gate
stock 25
splitfires
740cc
gtr pump
nistune
fmic etc etc..
now i had a grip day at mallala and the car was strong and did 15-20 laps, slight traction loss to limiter..
then i was exiting a corner (on the 15th-20th lap) and oil shot out my rocker covers..
then contnued for the rest of the day, when i exceeded 5-6000rpm..
i thought this was the usual rb issue so thought nothing of it..
bought baffles and rb26 rocker covers..
now i got the car to my workshop, to install plazmaman plenum, rocker covers and baffles..
got it on the dyno and excessive blowby, oil into catch can.. RINGS GONE!
any reason y the rings went all of a sudden?
tune related?
now im up for a rebuild!?
cheers
https://www.sau.com.au/forums/topic/325005-why-my-rings-failed/
  • Replies 72
Posted Images
First thing to do would be comp and leakdown as stated above and agree with the post above that 15 - 20 laps flat out would have your standard bottom end working pretty hard as cylinder temps would be right up there. What sort of A/F are you running and Does the nistune have air temp compensation ?. I would hazzard a guess that more than likely due to cylinder temp and probably some detonation that you will have a piston that has started to go soft allowing the crown to start to collapse pinching a ring allowing excessive blow bye But untill you do a comp and leakdown test you really wont know.
100% tune related.
the ring lands die from excessive heat and detonation. a 3076r @ 280rwkw on a 25 warrants neither.
its not to say it couldnt be user error, yet generally my cars see 30 minute floggings at a time and are yet to see this issue.
what are your AFs like? in the 12s i bet
you would think that 280kw wouldnt want to kill them...
does the tune have a big factor in this?
100% tune related.
See i'd argue that it was 100% tune related. You don't know that for certain.
5-7 laps will get a large amount of heat into everything that's for sure, especially upper RPM's.
You don't know the perevious history of the motor either. It might have had a rough life before the current owner as an example.
Could even have been running slightly lean for a number of reasons.
All of which are totally unrelated to the tune.
Either way I'm far from surprised. Tracking a motor @ around 2.5x the factory output - something will give eventually. :blink:
A few stock, good condition/low KM RB26's have been tracked for 2-3 years @ 300-330rwkw, they eventually have died also. Just how it goes.
There are also plenty of cars getting around with AFR's in the 12's on the circuit without a drama after years (these are built mind you).
Honestly what caused the motor to fail IMO could have been any long number of things, and perhaps not a singular one thing but a culmination of several.
Very true, that could be the missing link.
I guess we dont really know enough of its history to give an accurate opinion, with this owner or the last.
yeh al good guys.. the engine will be getting removed today..
i have a new bottom end arriving soon, just dont want this happening to the built one!
ill take some snaps of the bottom end wen it comes out.
also would i need to do any work to the head to bolt it to my new block?
It may have been tune related, BUT, parts can fail, as ash said you are pushing 2.5x the factory power output, parts in F1 engines fail and they have the absolute best of everything inside them, so I wouldnt just be blaming the tune.
yeh totally understand..
i wasnt expecting it to hang in there forever..
just wanted some enlightment...
ill strip it down and take a look and hopefully learn..
but ill start a build thread soon :P
For insurance, you could install a wideband AFR, and an oil pressure gauge. That way you can keep an eye things - eg if a FPR or fuel pump are flaky you will see the full load AFRs change and can take action before the motor pops.
Also - what oil were you using?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
