well i have (had) a rb25det s2..
gt3076r .82 @16psi
38mm gate
stock 25
splitfires
740cc
gtr pump
nistune
fmic etc etc..
now i had a grip day at mallala and the car was strong and did 15-20 laps, slight traction loss to limiter..
then i was exiting a corner (on the 15th-20th lap) and oil shot out my rocker covers..
then contnued for the rest of the day, when i exceeded 5-6000rpm..
i thought this was the usual rb issue so thought nothing of it..
bought baffles and rb26 rocker covers..
now i got the car to my workshop, to install plazmaman plenum, rocker covers and baffles..
got it on the dyno and excessive blowby, oil into catch can.. RINGS GONE!
any reason y the rings went all of a sudden?
tune related?
now im up for a rebuild!?
cheers
https://www.sau.com.au/forums/topic/325005-why-my-rings-failed/
  • Replies 72
Posted Images
First thing to do would be comp and leakdown as stated above and agree with the post above that 15 - 20 laps flat out would have your standard bottom end working pretty hard as cylinder temps would be right up there. What sort of A/F are you running and Does the nistune have air temp compensation ?. I would hazzard a guess that more than likely due to cylinder temp and probably some detonation that you will have a piston that has started to go soft allowing the crown to start to collapse pinching a ring allowing excessive blow bye But untill you do a comp and leakdown test you really wont know.
100% tune related.
the ring lands die from excessive heat and detonation. a 3076r @ 280rwkw on a 25 warrants neither.
its not to say it couldnt be user error, yet generally my cars see 30 minute floggings at a time and are yet to see this issue.
what are your AFs like? in the 12s i bet
you would think that 280kw wouldnt want to kill them...
does the tune have a big factor in this?
100% tune related.
See i'd argue that it was 100% tune related. You don't know that for certain.
5-7 laps will get a large amount of heat into everything that's for sure, especially upper RPM's.
You don't know the perevious history of the motor either. It might have had a rough life before the current owner as an example.
Could even have been running slightly lean for a number of reasons.
All of which are totally unrelated to the tune.
Either way I'm far from surprised. Tracking a motor @ around 2.5x the factory output - something will give eventually. :blink:
A few stock, good condition/low KM RB26's have been tracked for 2-3 years @ 300-330rwkw, they eventually have died also. Just how it goes.
There are also plenty of cars getting around with AFR's in the 12's on the circuit without a drama after years (these are built mind you).
Honestly what caused the motor to fail IMO could have been any long number of things, and perhaps not a singular one thing but a culmination of several.
Very true, that could be the missing link.
I guess we dont really know enough of its history to give an accurate opinion, with this owner or the last.
yeh al good guys.. the engine will be getting removed today..
i have a new bottom end arriving soon, just dont want this happening to the built one!
ill take some snaps of the bottom end wen it comes out.
also would i need to do any work to the head to bolt it to my new block?
It may have been tune related, BUT, parts can fail, as ash said you are pushing 2.5x the factory power output, parts in F1 engines fail and they have the absolute best of everything inside them, so I wouldnt just be blaming the tune.
yeh totally understand..
i wasnt expecting it to hang in there forever..
just wanted some enlightment...
ill strip it down and take a look and hopefully learn..
but ill start a build thread soon :P
For insurance, you could install a wideband AFR, and an oil pressure gauge. That way you can keep an eye things - eg if a FPR or fuel pump are flaky you will see the full load AFRs change and can take action before the motor pops.
Also - what oil were you using?
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
