well i have (had) a rb25det s2..
gt3076r .82 @16psi
38mm gate
stock 25
splitfires
740cc
gtr pump
nistune
fmic etc etc..
now i had a grip day at mallala and the car was strong and did 15-20 laps, slight traction loss to limiter..
then i was exiting a corner (on the 15th-20th lap) and oil shot out my rocker covers..
then contnued for the rest of the day, when i exceeded 5-6000rpm..
i thought this was the usual rb issue so thought nothing of it..
bought baffles and rb26 rocker covers..
now i got the car to my workshop, to install plazmaman plenum, rocker covers and baffles..
got it on the dyno and excessive blowby, oil into catch can.. RINGS GONE!
any reason y the rings went all of a sudden?
tune related?
now im up for a rebuild!?
cheers
https://www.sau.com.au/forums/topic/325005-why-my-rings-failed/
  • Replies 72
Posted Images
First thing to do would be comp and leakdown as stated above and agree with the post above that 15 - 20 laps flat out would have your standard bottom end working pretty hard as cylinder temps would be right up there. What sort of A/F are you running and Does the nistune have air temp compensation ?. I would hazzard a guess that more than likely due to cylinder temp and probably some detonation that you will have a piston that has started to go soft allowing the crown to start to collapse pinching a ring allowing excessive blow bye But untill you do a comp and leakdown test you really wont know.
100% tune related.
the ring lands die from excessive heat and detonation. a 3076r @ 280rwkw on a 25 warrants neither.
its not to say it couldnt be user error, yet generally my cars see 30 minute floggings at a time and are yet to see this issue.
what are your AFs like? in the 12s i bet
you would think that 280kw wouldnt want to kill them...
does the tune have a big factor in this?
100% tune related.
See i'd argue that it was 100% tune related. You don't know that for certain.
5-7 laps will get a large amount of heat into everything that's for sure, especially upper RPM's.
You don't know the perevious history of the motor either. It might have had a rough life before the current owner as an example.
Could even have been running slightly lean for a number of reasons.
All of which are totally unrelated to the tune.
Either way I'm far from surprised. Tracking a motor @ around 2.5x the factory output - something will give eventually. :blink:
A few stock, good condition/low KM RB26's have been tracked for 2-3 years @ 300-330rwkw, they eventually have died also. Just how it goes.
There are also plenty of cars getting around with AFR's in the 12's on the circuit without a drama after years (these are built mind you).
Honestly what caused the motor to fail IMO could have been any long number of things, and perhaps not a singular one thing but a culmination of several.
Very true, that could be the missing link.
I guess we dont really know enough of its history to give an accurate opinion, with this owner or the last.
yeh al good guys.. the engine will be getting removed today..
i have a new bottom end arriving soon, just dont want this happening to the built one!
ill take some snaps of the bottom end wen it comes out.
also would i need to do any work to the head to bolt it to my new block?
It may have been tune related, BUT, parts can fail, as ash said you are pushing 2.5x the factory power output, parts in F1 engines fail and they have the absolute best of everything inside them, so I wouldnt just be blaming the tune.
yeh totally understand..
i wasnt expecting it to hang in there forever..
just wanted some enlightment...
ill strip it down and take a look and hopefully learn..
but ill start a build thread soon :P
For insurance, you could install a wideband AFR, and an oil pressure gauge. That way you can keep an eye things - eg if a FPR or fuel pump are flaky you will see the full load AFRs change and can take action before the motor pops.
Also - what oil were you using?
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
