Hey Gang,
So basically adobe flash updated to version 10.1 on friday/saturday i think it was, go to watch a you tube vid on Sunday and Blue Screen then restart! Arrrggh!
googled the issue and it appears it has happened to others, might be an issue with the latest release and running catylyst 10.3
Sooo i uninstall flash player 10.1 using adobes uninstall tool, then try to install a previous version of flash, but each time i try to install it, it defaults to 10.1 of flash again and surely enough it crashes.
By any chance do any of you guys have an older version of adobe flash exe? or is there something i am not doing right!
I finally 2 months ago got broadband, so one of my simple pleasures thus far has been you tube....... not any more and i cant be bothered waiting for all that time of a new version of flash to come out again!
https://www.sau.com.au/forums/topic/325025-adobe-flash-player-crashing-my-pc/
hehe, this is why i never update drivers/versions in the first 2 months unless i need a problem fixed :P
Uninstall flash, and just google for an older version.
Either that or uninstall CCC and backdate that to 10.2
I'm still on 9.1 :blink:
yeah i think i might have to go back on the catalyst driver, have googled heaps of sites, the exe name even says an older version of flash but when it installs it defaults to 10.1 every time??
Yeah will go back on catalyst. I remember though there was a huge performance increase in the newest version of catalyst drivers, full article was on Toms Hardware, which is why i didnt want to go back on it.
Will have to bite the bullet Nismoid unless if anyone else has any options?
  • 4 weeks later...
OK techie guys need ya help!
So just went from catalysrt 10.3 where i would get the BSOD whenever watching a flash video or you tube clip! it would restart after BSOD.
So i have now upgraded to catalsyt 10.6......... and .... still BSOD!
I have removed then reinstalled flash 10.1 with still no luck.
BUT i have also tried hunting down older versions of 10.1 with no luck, i DO find an older version and it says to "Click here to download flashplayer 9" but when i do it still defaults to re downloading 10.1 and surely enough installs as 10.1!
Anybody have any other ideas? I have googled and it seems a few others have had problems with no success, another answer was when the flash vid comes up to right click on the flash vid and select "disable hardware accelerator" sounds like a great idea but too bad my PC crashes before i can even click on a vid!
HEEEELP!!
  • 3 weeks later...
Reason for the crashing is Adobe using the GPU for processing as opposed to the CPU. CUDA technology for nVidia and something equivelent for the ATI.
Try getting the latest Catalyst drivers and Adobe Flash.
The issue could also be to do with the browser. Just as a test can you try both internet explorer and firefox. I've personally experienced Firefox going funny after some plugin updates (not saying this never happens to internet explorer).
Could be as simple as re-installing the browsers.
Also ensure your Java is at the latest version - java is known to cause crashes too - but rarely as spectacular as a BSOD :)
Have updated to latest flash and latest catalyst, eveything has been updated. uninstalled then updated again.
What i did find interesting though is, i used Google chrome that utilises HTML 5 and not flash, went to you tube and guess what..... BSOD!! Arrrgh! dont know what the hell is happening but all i know is that i might have to complete a full wipe of the HDD's and start again :-(
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
