Hey guys my engine has decided to produce a most unwanted noisey lifter...now as i said its only when the engine is cold and only at 2000rpm, goes away at lower and higher rpm...just wondering what people think of it..im pretty puzzled as i would of thought that the noise would get worse at higher rpm yet it goes away exactly as after passes the 2000rpm mark. ive chucked in some lifter free today but so far it hasnt helped, does it sound more likely to be mechanical failure of the lifter or just the lifter getting stuck? also the noise completely goes away once the engine reaches opperating temp...
as much as i would love to replace my whole set of lifters im looking at $88/lifter from nissan so thats roughly $2100...second hand motor is sounding more plausable..
https://www.sau.com.au/forums/topic/325034-noisey-hydralic-lifter/
I would suggest you try changing oil.
What are you running now? has it only started doing this recently in the colder weather?
My mates 34 GTT did the same thing untill we changed too Motul 300v 10w-40, within a couple of days it stopped doing it and hasnt done it since.
Probably just a bit of gunk stuck in the lifter, I would say the reason it goes away with more revs is that the oil pressure goes up with revs (more oil forcing it's way in to pump the lifter up) and the reason it goes away with temperature is that the oil thins out and will find it easier to get past the gunk.
My 2c.
I was running castrol 15w-40 when it first started doing it due to the high k's (180,xxx), so i put in some lifter free with no result. i then put in a engine flush ran the motor for about 20mins before draining and changed to 5w-40 and yet again added more lifter free...that was yesterday so im giving it some time to see what happens...an yes its only just started doing it in the winter cold mornings, but never did it same time last year so im ruling that out.
if i see no result i dunno what my next move will be...probally 2 bottles of engine flush and a long drive before i change the oil again to try flush what ever it is that is stuck inside the lifter out :D
i used to have an r33 gtst with 150k on the clock, that had a ticking noise that would only start once the engine was warm, the owner of the car tells me it goes away after an oil change, but returns later, that car also drove like a dream haha.
Something sus tells me that your tick is not a lifter... how do you know its a lifter?
Does the tapping occur on idle wen u rev to 2000rpm AND when your driving at 2000rpm ?
oh and btw FLN75S: r34 gtt's have solid lifters, running a thin oil will make them run slightly more ticky
Edited by snozzle
nah, i start the car right first thing in the morning so its stone cold and its quiet. if i slowly raise the revs as soon as it hits 2000rpm it ticks bust as soon as it passes or falls below 2000rpm it stops lol. the noise is definatly a top end tick just from listening to it. i just find it odd that its only at 2000rpm...once i start to drive the noise quickly dissapears as the temperature rises but i always allow the engine to reach opperating temperature before i drive it so its gone by the time i move the car.
hey man
i own snozzles old 33gtst with similar problem
fresh oil change with motul (make sure engine is hot when you drop old oil) works well
it will eventually came back tho, lifter free additives not advised best just to live with the noise or take it somewhere to get it fixed properly
car still drives like a dream though
also check cam cover/rocker cover screws aren't loose, they're all easy to get too and it takes 5mins
this dramatically reduced the ticking
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
