Heya all,
Just looking for general opinions on a setup for an r33 my mate recently purchased e.g. it's not making enough power, it's running too high boost, i would change that etc. Basically what to do, what's right for the engine/setup e.g. wind boost down or leave, add more support stuff etc.
It's an r33 with a series 1 rb25det.
It's been rebuilt 65000 kms ago with new nissan parts like rings, rods, gaskets/hoses etc
It's got a boxed pod, z32 afm, gt2871r .86 housing, fmic, head ported, valve guides trimmed (what does this do lol?), tomei valve springs, tomei ex cam gear (retard 4), 3"dump/front, 3.5"exhaust + hfc, 0.050 o/s bore, alloy rad.
In terms of support stuff for power, there's a nismo fuel reg, apexi power fc + boost control, some FET coilpacks.
It runs high boost 1.25 setting on the pfc hand controller (is this 1.25bar?) and that was around 240kw according to previous owner. Lowest setting is 0.90 on pfc hand controller. The daily setting is 1.1.
Opinions & thoughts? Mate is looking for response and average power (i.e. curve) not peak warp speed type power.
The car currently seems to run very well and has pretty good response.
for cam lift, and/or head flow, what size are the sticks?
BTW I think the turbo is a bit small for what you want, 240 sounds about right otherwise.
Great thanks mate.
The cams are stock, just the exhaust cam is adjusted via the cam gear.
I think my mate is happy with the power, though if there's a better turbo that gives more mid range and better top end...well that's just win!
Is he able to adjust the boost via the pfc without a retune (i.e. do the boost settings all run on one tune/map or each boost setting has it's own correlating map?)
Any turbo you chose will make more power, but at the expense of midrange compared to what is on there now.
That's just how the world works.
~18-20psi/240rwkw from that turbo sounds about right, it won't be making anymore power than that.
Great thanks mate.
one fuel and ignition map, up the boost to the max it was tuned for, i wouldnt suggest going higher than it was tuned for. stick it on the 1.25bar setting and leave it there, nothing wrong with running 18psi on that turbo everyday.
Thanks for all the helpful replies guys, much appreciated.
This is really good news for my mate, i'll let him know.
The reason i asked about changing the boost setting was not to raise the boost but to actually make low boost even lower - just so there was more gap between sedate and arse on fire mode. And yep E85 is on the cards.
Thanks all!
  • 4 weeks later...
Rather than starting a new thread hoping some of you knowledgeable folks can provide input here.
In terms of running the above mentioned car on e85, what flow upgrades are needed if needed ie.
With regards to fueling, the car has tomei 550cc injectors, nismo fuel reg, bosch 044 pump mounted in tank, and is bored to near 2.6l capacity.
Already have a tuner in mind so that's ok.
Thanks all.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
