hey all, my r32 with rb20DET is getting harder to start, i have to pump the accelerator to get it to start, when its warm its fine, any ideas? btw plugs have been regapped to 0.8, ive got a fmic, HKS evc, apart from that its stock as a rock.
theres a cold start valve on the r33. i think the 32 has one, and its easier to access. that could be your problem. it opens up to allow more air to the intake until it gets warm, then shuts.
if your idle is steady once started, i would assume your aac valve is working ok.
well thats what i thought lol, guess it just needs more air??, had a knock sensor trouble code and it just sounds normal when starting, cant really describe any odd sounds, just my fuel pump turning on and it cranking lol
really???? most cold start setups are richer.
check that the TPS is setup correctly
hold on. do you mean pump your accelerator before cranking it? or when you start it, it needs gas to bring the revs up or it stalls?
hey mate my car has being doing this. If i don't pick the revs up to about 1500rpm as soon as I start it it will stall any ideas what is causeing this only happens when the car is cold.
Just a thought, but could it be over fuelling? maybe almost flooding of sorts. I know whenever I rejetted a carby & went too far I would have to hold throttle open-not an efi I know but you have changed the amount of fuel going in it may be messing with cold start map
Ive had this problem with my 32 and my main factor was the afm ( air flow metre ). Its running good now besides from the pumping of the gas when car is on, try the AAC valve, give it a clean, its located at the back of the plenum near the firewall kinda, cant miss it.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
