Hi guys, just need help in finding a replacement for a hose I split. In the thread attached it is the first hose that is suggested to be removed.
http://www.skylinesaustralia.com/forums/Di...tml&hl=miss
Keen to know what it does, and what it is made (really hard and unflexible) so I can get an adequate replacement.
Cheers
https://www.sau.com.au/forums/topic/325107-need-help-identifying-a-hose/
looks like rocker cover breather of some sort... just get a rubber hose suited to oil as i would imagine some oil would get in that hose.......mite be able to get away with some heater hose, but just check it doesnt split after a while....
heater hose should be alright. on my other car the oil hose that drains to the sump split and was pissingo out oil. it was a weekend i could not get my hands on oil application hose. so i used a heater hose... the shop was adament it wouldnt hold for long... 12 months later havent changed it! to hard to get to and hasnt leaked !
Yeah, Heater hose would probably do the trick.
the hose doesn't really see any large numbers for pressure or anything, but as mentioned it does get oil over time.
most heater hoses are rated to a decent pressure and are usually rather resilient to chemicals so it should be fine. i don't see the point in it being as solid as they are, maybe it's more of a result of the continuous heating and cooling of the engine.
My thoughts as well but the U shaped pipe next to it is flexible so yeah was a bit confused. Anyway thanks for the input guys, I will just stick with the heater hose and replace when/if I need too.
Cheers
hi all,
yeah that's one of your blow-by hoses, really common for these to go rock hard and split from heat cycling as suggested above. A replacement will cost you around $40 from a dealer so use whatever you can, heater hose etc will still last a while. The one you have that split is made from rubber just like the other u shaped hose you mentioned just severely deteriorated.
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
