haven't been for a while.. might drop in for dinner.
Dinner was great man!
Will go again.
il be there :)
theres a room upstairs? :bunny:
meh i havnt been in ages, work depending ill try come down
Will be present.
Should make it for the start :)
Will b there
work permitting...
will be there :D maybe I could score more fuel vouchers :P
I finish work at 6. So will head down.
See ya all there.
How nice of you to all show up... Not...
:laugh:
^^ :D
I was a big laugh last night.
A total of about 8 members showed.
So was just a quick run down of the events we had, then we were throwing up suggestions of decent guess speakers.
So if you know anyone PM Admin as Bec said last night.
for guest speakers we are interested in companies, vendors, suppliers etc
but also memebrs who have something they can talk about
anything related to our club and common interests we all share
ie someone could do a presso on the new ipad and what it looks like etc and best use for it etc
it doesnt all have to be about 600hp GTR's etc and the latest turbo kit
i did one on the WD HD tv movie system
so members out there, if you have some knowledge on something it would be great to have you come to a meeting and offer a bit of time on an area of interest
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
