Hey, got some parts for sale, all parts are in excellent condition.
Located in Northern suburbs, VIC.
Either PM me or call me on 0402207219.
Complete R33 GTR Series 3 interior. Comes with front seats, rear seats and door trims.
Price: $2000
Apexi Power FC suit RB25 (no handcontroller).
Price: $1200
Defi Gauges and Control Unit (Boost and Oil Temp).
Comes with Greddy Dual Pillar Mount to suit R33 and Oil filter sandwich plate for oil temp sensor.
Price: $600
Price: $1200
is that brand new neva used?????
PFC is used but has only done about 10,000kms.
Hey m8 will u send to WA im very interested in the PFC
I will send to WA as long as you pay postage.
Thanks, Mike.
Sorry mate, seperating the front trims would make the rears worth nothing.
Let me know if you want front and rear trims.
Thanks, Mike.
Yeah i guess, dont need them but what would ya like for them???
You can have the pillar mount for $60.
It has a hairline crack under one of the gauges which isnt noticeable. I only just noticed it the other day when i removed the gauges.
Thanks, Mike.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
