as above i really need a stock exhaust to clear my EPA as its weeks overdue!
i have a turbo back 3" so im not sure whether i need to change whole system or just fit stock catback to aftermarket front pipe maybe someone can clear this up for me?
have cash ready can pick up asap
thanks
hey mate, ill have to get my back from a fellow member. but you can certanly borrow it if your in the shit located in rowville. also i reccomend changing the whole thing over if your only wanting to fit the stock cat-back. ppl who leave front 3' on get custom pea shoters made up, think kia reo lmao
hay mate
when i had an rb25 in my car i had a custom turbo back 3 inch in the car.
when i got canaried i just changed the rear muffler on the stock cat back and used that cat back.
cleared many epas and canaries with it.
on a fairly modified engine as well still kept nice and quiet.
u can borrow that if u want located in templestwe/donny area
cheers
julz
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
