Having trouble deciding which one to go with so it has come down to this. Is there anyone else who can tune the wolf 3d other than mildrens, someone who may be more skyline orientated. If there is i may go with the wolf however if there is not.....where is the best place in Adelaide to get a used apexi power fc + hand controller + boost controller. I know that there is a number of tuners who are capable with the power fc on a skyline. Any comments appreciated.
https://www.sau.com.au/forums/topic/32515-wolf-3d-or-apexi-power-fc/
Two Places....
My first choice is Tim @ RPM. He knows what he is doing, tunes safe and has always had no problems getting a R33 making 250rwkw without cracking ring lands for many thousands of kays. If your a regular on the forums you will see the problems people have had with the RB25DET's when up over 250rwkw.
Tim sometimes isn't in Adelaide as he tunes overseas (USA & some where in Asia).
Second is Tilbrooks.
Tim likes the Microtech's but also knows the PowerFC's like the back of his hand.
I have heard not to bother with a Power FC EBC if you go that path - apparently they are expensive POS's. Better to go a Greddy ProfecA or B.
The Power FC is certainly the weapon of choice IMHO. And I recommend Tilbrooks very highly!!!
What is wrong with them? Have you used one? I have absolutely no probs with mine, works like a charm. Same solenoid as the AVCR.
Definately a stand alone EBC will give you more features though.
No I've never used one Steve - I was just told that by a couple of different people. Not so much that they don't do a good job, but that other brands are cheaper and have better features. No offense meant mate :(
None taken:) I thought that perhaps someone has got a bodgey one, or didnt know how to set it up properly, or I just got lucky, but then again, I am not the only one that is happy with it.
Like I said before, if you just want to set and forget (memory is not battery volatile, so you can disconnect it as long as you like without upsetting it) the power fc boost control function is good. Most people I know just set the boost where they want it and leave it.
You are right about the features though. If I was after an standalone, I think I would be leaning toward the Profec or Blitz
Id say i would rather go the power fc in comparison to the wolf. In my opinion i would only got for say haltech/autronic/motec over the FC. I would look at getting it tuned at say tillbrookes, john keen (tuned my car to 244 rwkw standard sr internals, pulled motor down and is still mint condition) or maby even morepower.
I was curious with regards to Autotronic so I spoke to John Keen, He wanted around 5500 installed and tuned, I said the price was a little rediculious compared to the PowerFC and for what I'm going to use the car for.
I then asked about tuning a PowerFC, He wanted $600 and said they basically are POS with their little hand controller that is difficult to tune with. (Just after Steve had his done) We all know PowerFC's arn't POS.
Steve what features does the PowerFC EBC have?
Can you have different boost levels at different rpms?
No, its just a case of dial up the boost you want, you need to set the duty cycle, and then the computer does the rest. You get 4 different boost settings on the controller, but you can change any of them whenever you want.
All in all, if you want minimum fuss, a good setup.
$5500 ???
What are you getting , an SM2 with every option ??
Cheers
Ken
$5500 ???
Cheers
Ken
Not sure.. I told him I'm using the car for the street & it would be a RB30DET running the RB20t sensors/injectors(types) etc.
He said that was fully installed as it isn't a plug and play like the PowerFC & required wiring mods. Probably taking me for a ride.
Tuning he said costs around $800-1k depending.
The only negative I can think of with the PFC is injector impedance limitations, correct me if I'm wrong? Straight fit Jap side feed injectors (that snake will require if he goes to that level) are very expensive & usually require collars to complete the install, so the final cost adds up. Mind you if you get lucky with customs, or find some 2nd hand, I'm sure they can be bought for reasonable prices.
Other than the above issue (if I've got it right?) I'd say the PFC is a very solid choice of ECU. Having said that I couldn't be happier with my LT12 :D
Whatsisname, i have read about your experiences with your lt12 and was really tempted, the only thing that bothered me is that it is does not have closed loop, how is your fuel usage?
Also what did tim at rpm charge you to tune it? does it have good drivability?
I dont suppose anyone has had their car tuned at mildren race engineering? the local wolf dealer/tuner here. Just wanted to know if their capable of doing any tuning on a skyline regardless of ecu. I have a map from steve sst in WA to suit a wolf equipped r33 with similar mods to mine, i would assume that they could "trim the edges" of this map to suit my car but the end result will all come down to how good the tuner is and this is why im asking first. Any comments or should i just go the power fc or microtech route because i know the tuners in Adelaide are capable with these two?
Can't help you on the MRE question mate, as I (or anyone I know) have never had any dealings with them. If the tuner isn't familiar with the model of car then I would be hesitant, but I'd be even more hesitant if they were unfamiliar with the ECU.
Re LT12, yep no closed loop. The new LT16 has closed loop AFAIK. Joel may have more info on the LT16?
My economy is quite reasonable for no CL & 550cc injectors. I did 260k yesterday. I checked the fuel gauge before leaving & it was dead on the 3/4 mark. 260k later it's just above the 1/4 mark. My driving was faaar from economical :)
I really couldn't give you a price on tuning as it was over a few sessions & mixed in with many other mod's, sorry mate :D A very rough ball park guess of $500?
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
