This thread is shit hot!
These bad boys are great! I love these tools, they are perfect for race car fabrication duties.
Should be threaded insert gun does 4,5,6,8,10 probs similiar to Craved's one.
Spotting drills for deburing drilled holes, perfert chamfer everytime and it looks like it was done on a cnc!
Air rivet guns, makes light work when you got eleventy billion rivets to pop!
Just noticed this is a NSW thread...Im only a QLD'er, am I allowed to contribute??
Edited by r33_racer
This drill kit is is a must have,,,remember the last time you broke a drill bit and then needed another. Not anymore with this one. Just have to remind my self to buy replacements.
Cheers
Neil.
http://www.google.com.au/m/search?site=ima...tner%20saw#i=48
had to use yhis the other day to cut the trans tunnel out of a vn then cut the tail shaft in half to get a wreck off the trailer at work... Had no key and was in park... The selector on the trans was also rooted....
If you are serious about getting the most accurate torque settings consistently, virtually maintenance free.
Deflecting Beam Torque Wrench
Capacity - 20-220 ft.lbs / 30-300Nm
Drive Size - 1/2"
FEATURES:
- Dual signal ( see and hear when the wrench has reached the selected torque.)
- extremely accurate (+-2%)
Or if you want something more 'high tech' this one flashes, beeps & vibrates
If anyone is interested in either of these PM me, I have a pretty good hook up & may start a group buy if there is enough interest.
Or how about these, find that squeak in your suspension or useful for listening for knock whilst tuning
Wireless Chassis Ear
No....not that kind of tool.....
The "how do I get this old rubber hose off" thread reminded me about this idea.....so here it is, the cool tool thread.
What are the odd/unusual/invaluable tools you use!
Here is the opening item....
What: Hose Pliers
For: Saving your knuckles! Gets most hoses off, and after 20 years they can be damn hard to budge! Vacuum hoses, coolant hoses, breather hoses you name it.
From: Got mine from the tool guy that came to the show n shine....probably need to find a specialist tools shop
Cost: About $30
Used a set of these on Tuesday. Absolutely awesome and saved my knuckles.
Talking about torque wrenches I had to buy this bad boy for my centre lock wheel nuts. I think it goes to 700nm's.
Cheers
Neil.
Thats pretty awesome, haven't seem too many of them around, I bit overkill i would think for a wheel nut?? The wrench below is used on tank tracks & to tighten the bolts on the west gate bridge.
Capacity - 200-1000 ft.lbs / 260-1340Nm
Drive Size - 1"
Length - 140cm
Need a flashlight for working on the car? This is a CREE LED 330 lumen and runs on rechargeable lithium batteries. Thing is absolutely awesome.
<cut>
Nice, I use a Romisen RC-C6
Mainly because it floods a huge area when you use it, which is good when you want to look over a broad area.
Problem is the battery probably only lasts around 1hour, but the batteries are smaller than a AA so its not exactly hard to carry a couple around :)
Dunc I will be keen for that, one day. Lol street r33 or track car, whichever is working well enough to race with! Im secretly keen on the street car though. God im hoping it delivers the results im expecting! Im gonna blow everyone away! EVERYONE!!!!
Those torque wreches are huge! I believe they use that size to do up truck wheel nuts also!
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
