they are cleco's lol
stole some pics from here : http://www.6speedonline.com/forums/garage-forum/190631-project-garage-condo-25.html
basically they can be thought of as a removable rivet, will clamp 2 panels together through a hole while you work on the panel or weld it.
haha thanks Eric,
i figure get what i can when i can, cos hopefully i'll get to the point of needing them lol
too many plans, not enough time
think i just need a hoist now :)
die set was about $400 delivered, but made to order so took about a month to get them.
22... WTF am i going to do with a 22?
Landcruiser's mang. (I work for Toyota lol)
My most used tool at work
Only had to give them a kidney for it, it's a tough little fcker though
Also have a Kokon 3/8 flex head ratchet that i use for everything, it's got an easily opened head i can throw some grease in for a smooth as silk ratchet operation.
I scored an Oxy set from a mate the other day! bottles still have gas left but im wondering what happens when i need a refill? apparently BOC will only refill if you have an account and rent bottles from them???
Edited by battery
AFAIK no one will fill privately owned bottles anymore
better off trading in your kit for an LPG cutting kit. rent the oxygen bottle and use your bbq gas bottle for an easy multiuse swap and go service
LPG cuts as good as acetylene if you have the right kit.
I weld with it too and i have been told LPG is pretty average for welding... Im too cheap to buy a MIG or TIG...
Bit dodgy but is it possible to hook it up with another full bottle and come out with 2 half filled bottles?
Edited by battery
I recently bought a pair of 12" knipex pliers wrench from the internet and I have to say I am extremely pleased with them. I was unsure whether it was a gimmicky idea when I ordered them, but they are absolutely awesome, so much so I'm about to order 6 more because my dad and everyone at work now wants one. here is the site I bought them off/ some info about them: http://chadstoolbox....ier-Wrench.aspx
They are basically like a set of multi-grips, but the jaws are smooth and flat, and they stay parallel to each other all the time no matter what position they are in. It has replaced my shifter, and my spanners and my multigrips (for most tasks) all in one tool. Its far better for gripping and doing up nuts/bolts and all the smaller glands and lucknuts at work. It also works like a ratchet. It is literally 3 times faster and twice as secure than using a shifter for the same job. If you are a plumber/fitter/mechanic I would definately look into getting a pair.
PS: If anyone wants any other pliers, this is the site to go to. NWS Germany and knipex both make top notch pliers and you can buy them alot of them for around $20-25 a pair from this site. Thats the same or cheaper than the china/taiwan special at your local tool shop, and about a quarter of what you will pay for Knipex gear in Australia if you can find it
Edited by Crackfox
Duncan, I have a decent one you can borrow, the only thing for the skyline is you need a lead that plugs into the bottom of the coil pack and then onto the spark plug... I'll see if I can find this lead too if you want...
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
