How's this for cool tools? I got all this for $55 shipped to my door from HK. Gotta love sites like DealsExtreme. Take a while to ship stuff but uber cheap!
7pc Steel Dremmel Saw Blade Kit
4 piece Stainless Tweesers
3 different wool polishing tips (12 pces each)
6 piece dremmel Rotary File Kit
4 Titanium coated End Mills
and a MicroSD reader thrown in to boot!
On the topic of trolley jacks, a mate of mine has one that has a foot lever on it that you can use to get the pad up to the body, and lift it a bit, which is great if the jack is under the car a bit and you have bugger all movement with the handle.
As for cool tools, I can't think of much that I have. At least ones that are car related and not bike related. Something I plan on purchasing in the near future though is a split collet bearing removal kit.
Fellas, which websites would provide the best deals on Sidchrome/Kincrome items?
Am after a new socket set (a comprehensive one), an air compressor with rattle gun and a few other bits and bobs. Also need a bench top/table :)
Raj try VEK Tools in Smithfield - they always have a good selection in stock. Bunnings stock Kinchrome and Sidchrome too. If you are after a more comprehensive selection though, go with VEK. They are online. There is another VEK Tools in McGraths Hill if that is closer for you. If you are up for a drive there is Hawkesbury Toolworx in Nth Richmond - this one is a bit of a hidden gem, it is a small, but comprehensive, family owned tool shop.
Thanks Terry and Tim. Appreciate the heads up. Will definitely check out VEK - I have been hearing a lot about them.
I read about a few bargins that could be found online - a particular Sidchrome socket set at Repco had a price tag of $300+ and the same set was found online for $190 brand new! So I thought its better to ask around and seek the best deals before spending big dollars.
This drain plug socket is worth it's weight in gold!
very cool....where did you get it? I bought a whole bloody set to get one of those, would love to know where to get one on it's own
I use http://www.transquip.com.au/, good prices on kinchrome. But bunnings is hard to beat for one off items these days. They do guarantee lowest price
  • Like 1
I have to get one of those. Is this the one you got Eric?
DP1314 Teng Tools 13mm Square x 14mm Hex Drain Plug Socket
Is the idea that you then use a 14mm socket on the end to operate it? Dunno why they don't just use a half inch drive hole.
Thanks Eric. And Adam the one I have has 19mm hex on the other end, I've also got no idea why it's not just 1/2 square....I always forget and pick up a ratchet....
Rob I've got something similar and it's invaluable when putting engines back together for the initial checks. In one case it saved me a world of trouble shooting when it helped identify a tiny leak in the turbo water banjo.
Adam, yup that's the one. The hex body is 21mm and 14mm at the end. I need to get a 21mm spanner. I used an impact socket when I could reach, but the trans in the tunnel fowled the GTR front drive shaft. Grrr, had to use an adjustable spanner along side the drive shaft.
But still way better than rounding the insides with a 1/2 inch drive. Amazing how much that 0.5mm makes such a difference in torque.
  • 4 weeks later...
Looks good Duncan, still a bit pricey unless you where doing a lot of them each week, so I'll stick to the manual one for the moment.
I got a set of these http://www.machineryhouse.com.au/D108 the other day, they are really good for notching tube and hole cutting in thick section material.
    • This sounds like a perfect excuse to install a Haltech R3.
    • I do believe from context he is talking about a S0/S1 R33 RB25 with associated ECU and Wiring for that, and a manual gearbox into a R34 N/A Auto. I don't have the knowledge of all the pinouts and such but my gut feeling from doing my own conversion is to use as much of the R33 stuff that you can. The "car" wiring is quite seperate from the "Engine" wiring when all things are considered. The only things to truly consider 99% of the time is the cluster, reverse lights and potentially disabling the 'not in P/N' immobilizer circuit.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
