Ratcheting tap wrenches are heaps handy!
Coupled with a spiral tap which doesn't need to be backed off to break the chip makes tapping in tight spaces a dream. -(not a particularly good dream. ..)
Explain how they work for me?
All I'm picturing is a ratchet like a 1/2 drive ratchet, so each time you need to back turn, you gotta flick a switch. Unless these have some other swanky ratchet setup?
Spiral flute taps ftw
Agree, I only use spriral/machine taps as they give a more accurate thread profile. I also find them stronger, but it's possible they feel that way as they're only produced by decent manufacturers.
Back in my CNC machining days I could spin smaller spiral taps a few hundred rpm and get perfect finishes repeatedly (in a production CNC environment I could do hundreds of accurate threads with one tap).
Mark :)
  • Like 1
Saw some drill taps at the tool shop the other day. Unsure if I'd trust it. Anyone use these?
http://www.machineryhouse.com.au/T0191
Work really well If you buy the American ones
But...I wouldn't use a Chinese tap if you paid me
  • 5 weeks later...
How much were they?
Haha not cheap, didn't feel too good about cutting them up haha.
Jump on ebay, the two triangular ones are "blue point" and the read rail-type ones are "ernst low profile" and the one with the stubbies is "ernst stubby"
Nobody else is buying stuff for their toolboxes?
I bought some Ernst and Bluepoint wrench racks from eBay -nothing beats an organised tool drawer :D
Not for the tool box... I've started hanging tools up in the garage though... Starting to look better :D
Waiting to get a power adapter so I can get the new MIG welder out though :D
What about pics of tool organisation?
I'm trying to come up with ideas of how best to setup my new tool shed.
Hang em all up? Put em in a tool drawer? What about bigger stuff? And the odd one off stuff/tools? How to store/ organise power tools?
Organize by levels.
I have all my tools organized in different levels of chaos.
i.e. a draw of screwdrivers, a draw of sockets, a draw of spanners.
All the extra time taken looking for tools is useful because it usually takes at least 1 beer to find anything.
  • Like 1
Organize by levels.
I too have this logic in my garage. Works a treat.
Cool tool? My latest buy from Snap On. Cordles 3/8 rachet. Best thing ever when im doing engine bits and pieces including gearboxes or a head.
Best thing i claim it all back on tax as im a licensed mechanic ;)
That reminds me, I really should grab my Air Comp back out and set it up, I have an air ratchet sitting there that's probably going to help me a lot more than doing the ratchet by hand.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
