After seeing the above, I got this one for $30 + postage.
http://www.ebay.com.au/itm/311514221310?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'll let you all know how it goes.
Also bought this about 12 months ago from Germany. Great for rivnuts in hard to get at places, does both nuts and threads.
Not sure if the address is the same business, I just found it and used it for the photo etc.
http://www.ebay.com.au/itm/Nutserts-Nutsert-Setting-Tool-M6-M12-Riv-Nut-Rivnuts-Rivet-Thinsheet-PNT210-/230986691661?hash=item35c7e1344d:m:mf7e5tV-YTV5NApZL8tut9g
Yeah I ended up going the same one, the only frustration was it doesnt come with M5 or M4 mandrels which would have been an obvious inclusion for such a compact tool. Who the hell uses rivnuts to hold an M10 bolt??
  • 4 weeks later...
So, I'm not sure if this actually classifies as tools but I'm really happy with these. The transition between my garage and driveway sucks. Without some boards, it scrapes the front lip even at stock ride height it ruined my OEM lip.
I have to get rid of the old board and cut a 4 x 6 on angle to replace those old boards.
  • Like 1
  • 9 months later...
Half moon obstruction ring spanner - Take that you pesky inaccessible fourth turbo nut you!
It's not quite perfect, still jams against the turbo front outlet, but better than nothing...
  • Like 7
I love these!
So good for header bolts/turbos
  • Like 1
Brilliant! Just ordered a set and I'll give them a go. Thank you!
  • Like 1
Me, used the M10's for attaching my Grundfos water pump to a welded up pedestal which in turn is SS dyna bolted to the pump shed floor, now I can pump water from my bottom tank to my top one....hehehe
  • Like 1
Also, what does everyone use to get to the water drain on the block, the one behind the turbo?
I tried a few different spanners and sockets and just cannot get a purchase on it, one thing I do know, when I finally get it out I an going to make one up with an extended head like 40-50mm hex bar and 50mm long as well.  Its a PITA to get to with anything decent.  Needs room for a breaker bar!!!
I cut a spanner in half then got a larger spanner on the back of it for leverage. Just enough room to turn it with the cut in half spanner after you break it loose.
  • Like 1
  • 9 months later...
Sort of; in that I have one in boxes on the shed floor.
When we moved out of the old place I've had to leave the hoist behind because
1/ I can't get 3 phase power here, and
2/ the shed roof is about 0.5m too short for the hoist I have.
So as this is kind of temporary (for a year or 3....), I grabbed one of these. Not unpacked or used yet, I haven't had a job that needed it so far but will have to change the sludge/oil in the bush basher soon enough and replace the water in the brake lines with brake fluid, both of which will give me a reason to give it a go.
Without having used it yet, thoughts from me are that it is very expensive (a full hoist is the same price or cheaper) and obviously won't let you stand under it but this is easy for clearance, has no install cost or requirements, is portable, and has no overhead clearance issues.
  • Like 1
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
