that picture is from http://www.engineeredtoslide.com
he uses double spacers under the lift pads to get extra height, so would need to jack it up first
my cars all go on fine, but my 33 is 100mm legal height
yeah, you can see the holes in the black post in the picture.. one has the silver locking bar in it for max height. at the base of the arms.
just a 20mm rod of steel through holes, other position is half height
  • 3 weeks later...
I finally used mine on the weekend to take the race tyres off the leaf and return it to road life.  About 2 hours from wrapped in plastic to wheel change complete. There's a bit of stuffing around bleeding the hydraulics the first time but very straightforward to use. I've got the 12v version so it is theoretically portable, but each frame is very heavy to lift.
Probably slower than a jack and stands on a car where you have it down pat, but it does lift stuff off the ground which is the whole point. And lifting by the sills keeps the underside of the car nicely accessible.
But it doesn't seem like good value for occasional/weekend use to me. Also, if you buy one check the measurements of the jack against each car you want to lift. The Leaf is just hatchback sized but the biggest quickjack only made it by about 200mm
I'm leaning more towards the Happ Half height. They have been great to deal with so far.
Just working out where to put it in my shed to maximise height and usable floor space but also still working through how long we think we'll stay here.
  • 8 months later...
Is this thread still a thing?
Picked up one of these to make clutch changes on stands a hell of a lot easier.
Specs at http://www.tqbbrands.com.au/jacks-stands/transmission-jacks/tradequip-2081
Picked mine up from VEK tools for under $600 and have used a handful of times so far. You can also buy from the snap on man and it comes with a bluepoint sticker instead of a tradequip sticker lol.
  • Like 4
Have to spin my box around 90deg to get it out and in. Is it still possible with one of these or does it get in the way?
2081.jpg&key=556ee9986745444fdd957477ad618ba550189448ab6dc7a944af8b389bfd14ee
I haven't used the floor style one, but on the hoist style one which is effectively the same but taller...yes you can still rotate the box to clear that hump.  Just need to undo the safety chain or leave it loose.  The 4 fingers that stick up are also adjustable or removable if they get in the way.
That style of jack is a lot more stable that the regular small pad floor jack.
Besides a proper hoist
this thing and the 10mm socket is my second love614A9542-64B7-4675-B142-AD3D52C898C8.thumb.jpeg.55fd85f244df787bb5db72bb431408b2.jpeg
I just grabbed a cheapie to try, Oh and a battery adapter coz f**k buying new specific ones and I wasn't spending over 300 to get the AEG multi tool plus ratchet adaptor combo when I just wanted the ratchet..
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
