4 hours ago, ActionDan said:
The pin/hinge and adjusting knob interest me, how have you got that setup and where'd you source the bits?
It's just a cheap one off Ebay-
https://www.ebay.com.au/itm/331881988969
I chose this one as it comes with the thread in the base of the mounting post.
I bought a threaded rod and nuts if I need a longer adjuster.
  • 1 year later...
It’s just dumb to have such similar designs that are only half compatible…
This is my latest tool “investment“.  I’ll use them for everything I’m assembling that I take photos of to put on Insta (ie. nothing….)  On Project Binki they call them the “show spanners!”
I’ve wanted them for ages so finally convinced myself they’re worth it when they’re actually totally not but meh. 🤷🏼‍♂️
  • Like 1
On 28/12/2021 at 1:27 PM, Ben C34 said:
When you realise how Phillips head is designed to cam out when the torque is high it is f**king ridiculous it is still in use.
Must be cheaper to make...I would have thought that they would all go to allen key head or even torx...wish that they did, its easy to chew out a phillips/posidrive/jis head with a drill or impact driver.  Both doing up and undoing, lost count of the times I've had to use a dremel and cut a slot into a screw or bolt then 'shock' it out with a manual impact driver to get it out.
FYI for info on the phillips/JIS/Posidriv/Torx/etc options  check out https://en.wikipedia.org/wiki/List_of_screw_drives
Looks like the 'Vessel' brand does JIS, anyone have other suggestions on brand (or shop)?
https://www.sealey.co.uk/product/5637750680/4pc-jis-screwdriver-set
  • Like 1
But, where do you ever come across JIS fasteners? Not in a Nissan thankfully.
And those long spanners are nice to use, but they just aren't feasible in most tight locations.
They’re like most specialty spanners ( S, C, stubby, ratcheting, high offset, etc) they’re shit for 95% of normal spanner jobs and absolutely essential for the 5% of situations where nothing else works. THAT is why you buy them, not for the presumption that 1 spanner fits all.  I have a stupid amount of different spanner sets now of which I will probably only use about 10% of but I’m sure you’ve been in a situation where nothing fits and it sucks balls.  I’ve wasted hundreds of dollars to avoid that incredibly rare situation but I think I just like collecting spanners! 😂 I should take a pic of all my different sets as I think I might even scare myself once I laid them all out….
  • Like 2
  • Haha 1
Have not seen many electrical tools mentioned so here are two I like. I'll see what else I can come up with.
1. Connecter depinning tools. I often see people stabbing away with a flat screwdriver only to crack and destroy their old connectors.
2. Cable tie gun. This will tighten and cut cable ties in one shot. Very practical and quick when you have 100's to do.
  • Like 2
  • 2 months later...
Wait until you realise there's now a fastener/driver made called Torx Plus, and a Torx driver fits Torx plus heads. But under hogh torque will strip the driver or head...
  • 3 weeks later...
Yep, they basically have a double thickness star point.
I swear they purely make different fasteners so they can sell more tools.
  • Like 1
  • Haha 1
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
