On 17/04/2022 at 9:13 PM, luke gtr said:
Yep, they basically have a double thickness star point.
I swear they purely make different fasteners so they can sell more tools.
You telling me there's no reason to have a 5 star head, and 6 point torx will suffice?
Or having different Phillips head screws other than JIS?
Basically they call if for "security", so people dont work on cars that dont know how.
I just believe in a big conspiracy.
Ages ago I bought a 60 piece toolset that was supposed to do all these 'new' styles, triangle and 5 side 'allen head' types, torx pin and non pin, forked screwdriver blade etc etc...and I swear that as soon as I bought it, they just turned round and invented a whole new range of fasteners🤢
  • 2 months later...
I'm no wood elf, but I was stripping varnish off some old furniture the other day, initially with paint stripper then sanding it down. Varnish clogs sandpaper like crazy, long before the actual medium is blunted.
I discovered this stuff, which is basically just a softish rubber stick, as long as it is not too glazed it pulls the varnish off the paper and makes basically like new again
https://www.machineryhouse.com.au/g183
  • Like 1
I bought one of these
https://www.ebay.com.au/itm/332892255127?ssPageName=STRK%3AMEBIDX%3AIT&var=542005549749&_trksid=p2060353.m2749.l2649
and then went straight out and bought another one. VERY handy if you have adjustable suspension arms; they're perfect for getting in there for making adjustments, then just tightening up with a Big Boy spanner when you're done.
  • 9 months later...
I was reminded by another post to put this up.
I bought one these, haven't used it yet but should assist one person balancer and flywheel bolt do and undoing
https://boostdoc.com.au/products/crankshaft-lock-for-nissan-rb
Crankshaft Lock Nissan RB Toyota subaru honda SR20 KA24
  • Like 2
On 4/10/2023 at 8:26 PM, MBS206 said:
Have heard of people trying to undo balancer bolts, and not using one of the flywheel locks, instead, jamming the car in gear... Broken gears has been the outcome on some cars...
I absolutely refuse to believe that.
Basically a static load. No way would it break a gear.
"Jamming the car in gear" or just, you know, putting it in gear.......
Very dramatic story.  Not believable.
  • 5 months later...
Ben, just keep in mind MSB also thinks hitting stuff with a hammer fixes everything.
I like Duncan bought the flywheel stopper and his engine lifting brackets.  I just bought boostdoc's engine stand adaptor, things great.
  • Like 1
  • 2 months later...
Small, but great for little jobs
100% easier than sanding 99% of car brackets
I test drove it on a little section of the alloy wheels on the Honda that I want to repaint, works surprisingly well for a little job thingie
If you capture the garnet, the amount you get in the 1kg pack that comes with it should last a while
For $60 bucks it shits on hand sanding like a peasant
Going of my little test area, it should take me no more than 10 minutes a rim, the last set of alloys I sanded by hand, like a peasant, took at least an hour or more for each rim just to get all the clear coat off
  • Like 4
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
