So, I've always had a personal dislike for cordless tools. Why? Becuase you end up getting duplicates of all your tools and the batteries only ever last a few years. I have power tools that are 12 years old and only because I had to go 240v when I moved to AUS!
I Love this idea! God I hope that Black & Decker releases it here!
http://blackanddecke...ar-tool-system/
  • 4 weeks later...
But
Check out this
http://productinfo.kemppi.com/flipbook/prodcat_2012/en/files/mobile/index.html#11
The ezy weld series is flipping awesome
Pretty much weld themselves and you just hang on
The 170 is about 1800 bucks
I want one so bad!
  • 3 weeks later...
I must say my Abw torx bit set has got me out of a heap of trouble lately. Stubborn Allen key bolts are made easy. Stripped Allen key bolt heads made easy and snapped bolt removal made easy. Well worth the money. Also my 24mm ratchet spanner.
got links Brad?
Alex I've got a W&B beam type wrench as well, have had it for years and checked it twice, both times it has still been good - I think the design is more accurate than the more common spring type ones.
On the downside it is harder to use quickly than the spring/clicky type, eg for wheel nuts, you need to reset it with the pin each time.
Also, it only works clockwise so you can't use it on reverse threads (eg centre lock wheel nuts).
There are lots of digitial you beaut ones out there now, not sure if they are any good or not? I can't see how they would stay more accurate over time if they are still spring based
Ok, who's had to resort to making their own tool to get a job done?
Watch the "Movie" here: https://vimeo.com/48171832
that was awesome, Eric :) not just the ingenious tool and machine work that went into it but the quality of the vid!
I must admit, when I saw the welder spark up I thought at first you were using an oxy to cut the bastard off or something :rofl2:
I got mine from our tool guy that drives around.
http://www.norwesttools.com.au/page/shop/flypage/product_id/30266/a/category/e/automotiveservicetools_fastening
Thanks. The saga continues. Aggro and I battled it all day and well into the night on Sat, but motor is finally "hanging" in the engine bay and pump is off. Gears look in great shape which is terrific peace of mind, but now have to decide if I should roll some new ones in or not.
I'm looking for a rechargeable impact wrench - mostly for wheel nuts as i already have a highish torque air powered torque wrench. I'm thinking of this one, but DeWalt is probably overkill for my needs - but its a good price for quality - $359 with two batteries and charger. Any other suggestions? Spending a bit less is always good.
http://www.ebay.com.au/itm/DEWALT-18v-Cordless-H-Duty-1-2-Drive-Impact-Wrench-Combo-Kit-3Yr-AusWide-Wrnty-/290683597207?pt=AU_Power_Tools&hash=item43ae17b197
The spring type torque wrenches will hold their calibration well, as long as they are not left in a set position for a long time, if you are not using it, the tension should be taken off of the spring, if you need a torque wrench that will be used for one tension only, then a beam type is more practical, as long as they do not get over torqued and deformed.
I have a Kincrome rechargeable impact wrench, a bit on the expensive side if you buy retail, but so far hasn't let me down, and works well on the center locks for the Speads.
Here's another bit of kit I picked up at Hare & Forbes (Machineryhouse).
Oh and their showroom floor is better than santa's workshop! If you haven't been there and live around Sydney it's worth a wander. But leave the credit card at home or else risk walking out with a full size stand up mill!
I do love that place. most of the stuff is chinese cheapy....but hey that's what brings it into my price range.
I recently picked up drill press, grinder, sandblaster and parts washer there.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
