My favourite tool for a couple of years even if I don't use it that often. I feel so powerful holding it:
Sidchrome 1/2" 750mm long Breaker Bar
Think I got it for $80-90 including delivery. Probably got a receipt somewhere. My new favourites are gonna be ratchet spanners/wrenches when I get my own set. Been using a mate's and it is fantastic. Now I can't live without em.
For $30 at Supercheap can't go wrong. PS: the Teng one is on backorder, they have run out of stock. So sick of ruining 1/2 ratchet ends :)
What are Teng tools like? Always see them here and there for sale but never played with one. Are they decent? Somewhere in the vicinity of Kinchrome/Sidchrome quality?
Saw some crow foot spanners with their name on it a while back and thought I might ask here.
A simple little purpose built tool I made to Compress the piston in my R31 Rear Calipers.
(needs to be pushed in and turned, Clockwise for Passenger and Ant-Clockwise for Drivers side)
2 Sparkplug spanners and a bolt.
fits in here.
Works a Treat. :D
fits in here.
Works a Treat. :D
Love it, but what's the chances you'll loose it before having to change rear pads again! ;)
  • 3 weeks later...
Can anyone suggest a good rivnuet tool/tool set.
Keep in mind I'm a wanker and like to have trade quality tools ready for me to use only once a year...
Was looking at something like this http://www.memfast.co.uk/shop/Vprod1.asp?cat=2258004632 -thoughts?
This one looks like a damn good set; and it has both alloy & steel nutserts. I use these inserts on everything now I have them.
http://www.ebay.com.au/itm/214-PC-BLIND-RIVET-NUT-RIVNUT-NUTSERT-TOOL-KIT-M3-TO-M8-/120760789836?pt=AU_Car_Parts_Accessories&hash=item1c1de76b4c&_uhb=1
!C!O7TBwEWk~$(KGrHqQOKiwEzTEGN,lvBNCJr9L
everywhere man, they are the coolest of the cool tools. basically they insert a knurled nut into sheet metal so you can fix a bolt into it. mostly m6 ones for holding race car stuff in place, although I wouldn't trust them for anything serious.
I'm looking for one too...but would prefer the type shorter type with handles that turn rather than the style Dale posted which require a lot of clearance to use. One like this: http://www.wurth.co.uk/hand-tools/riveting/rivet-nut-tools/ratchet-rivetnut-gun-kit, or possibly the one rob posted, I've never seen/used that style
btw very interested in this option too...anyone used this style? I like the price, small size, and don't care it might be slow when it's not used that often.....
http://www.ebay.com.au/itm/Rivnut-Rivetnut-Nutsert-Fitting-tool-M4-M5-M6-Kit-car-rivet-nut-special-insert-/171218249071?pt=UK_Hand_Tools_Equipment&hash=item27dd67256f
  • Like 1
That Wurth kit looks good -their tools are generally quality too
I have one of these ones Duncan; as long as you lube the screw and ramps it works great, & will last fine for home use.
You can use it in very tight spots, which is why I ended up with it. :yes:
Like when you want to dodgy up a not so closed off 'cold air' box with aluminium? Or maybe I should stop being lazy and do some welding.
But on a serious note, this looks very interesting! Like maybe fitting undertrays and the works on your track cars?
Nutserts are awesome.
I use them on fibreglass shelled Lotus' and Radicals often, but use the deeper inserts with a washer on the back face (before being pulled), this stops the nut pulling through the fibreglass with time.
The Wurth stuff is expensive, but they do work well and are reliable.
NK7
If you have a working undertray, nutserts will not do, they'll pull through easily. A decent undertray will create well over 100kg of downforce and require mounting to decent chassis/subframe supports to reduce flex.
These are great for mounting stuff to sheetmetal, like boot mounted surge tanks and firewall mounted hose supports.
Mark :)
  • Like 2
NK7
Mark :)
Ahh I see... so after a while they can wiggle loose? But still sounds great. And not overly expensive and reuseable!
Heya NK7,
They won't wiggle loose if done correctly, but they're not designed to take big loads. I guess the specs would tell you different, but when you've got 100kg+ trying to rip the splitter off at speed and ripple strips slamming into the front corners under cornering, I'd prefer to use something a little more substantial (nut/bolt to chassis rails).
They're a great tool to have around and your mechanical will love working on the car with less ninja self tappers through firewalls and floorpans! Those farkers will tear you open at every chance they get...
Mark :)
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
