This wire isnt connected, the pump is running as per usual.
i opened the tank up tonight to see if remounting the pump could reduce a very loud whinning the apparently 33 GTR fuel pump makes.
Assuming the pump was ran out dry hence the loud noise, as remounting made no difference.
What does this wire do exactly, does anyone know?
It's meant to connect to that capacitor looking thing right near it in the picture.
Traces back to a yellow wire with a blue stripe.
Aaaaand, what other cradles can I use?
Cheers guys.
https://www.sau.com.au/forums/topic/325200-fuel-pump-running-with-a-cut-wire/
S13 is no good. It's about 6cm too long and fouls on the bottom of the tank.
I'm going to try to cut/weld mine to fit, but it will be a few weeks before I get around to it.
A32,B14,B15,D22,N15,etc all have the same bolt pattern for the lid, maybe one of those would be a closer fit...?
I switched t he pumps between my road Ceffy and the project.
The project one had an inbuilt filter at the bottom of the pump, and fitted fine...the other one didn't, and with the filter on, it wouldnt quiet fit.
I cut the end of the bracket off with an angle grinder (stupidly, while the bracket was still soaking wet in petrol....nothing happened though, woo), to make it fit.
The pumps themself looked the same size except for the filter adding some length.
Does this mean there are different brackets that came from the factory?
Donar was from a 20DE (turned 20DET), the tank it went into was a 20E.
One more thing...the Ceffy with the supposed GTR fuel pump, had a pressure rego in the cradle, but the project one with a factory pump setup didnt....possibly a GTR cradle+pump both used ?
I'm using a GTR pump in mine right now. It has a rego on the top of the pump, not on the cradle.
I dont think you have a GTR Cradle. In R32/R33 GTRs (all GTRs?) the cradle is not part of the lid/sender assembly, it is mounted to the bottom of the tank.
Be careful if you use hose clamps to attach the pump to the cradle. I think I tightened mine too tight and squeezed/ruined the pump. It started whining, so I tightened it, and it got worse. :down:
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
