Hi guys,
i had a good look under by steering dash column tonight and found the greddy turbo timer plug. It appears my car used to have one and coincidentally i bought a greddy tt awhile back to install. I regrounded the ground wire and when i plugged it into the plug, nothing happened and the powerfc started to flicker on and off real fast :S I didnt have the handbrake wire hooked in. Is this necessary for the operation of the timer to work correctly? Anyone have any suggestions to what it could be?
Terence
https://www.sau.com.au/forums/topic/325213-turbo-timer-install/
Wires cut open anywhere after the harness ? Where did you reground it to ?
Doesnt need a handbrake wire, that's only to affect if the turbo timer keeps the car running when it cuts off (ie if handbrake isnt on (you stall the car) it'll shut off straight away, if handbrake is on (parked the car) it'll keep it running before shutting off).
