Chatter Noise Under Load
Hi All,
I was driving my R33 home from work today and noticed when accelerating from 80 - 100 in 5th under heavy load there was a chatter coming from the engine bay somewhere. Not too sure what it is but I did notice that my A/F ratio is running pretty rich (13 - 13.5)
I took off the pod recently and put back the stock airbox however I think the SAFC was tuned with the pod on.
Any thoughts on what the sound might be?
14.7 is stoich, but you only use that for cruise. when it comes to putting load on in a turbo car then you want things to be 12 or less (anything higher than about 12.5 at high boost and rpm is going to have a short life), however at 80 to 120kmh in 5th gear you are pretty low in the revs so 13.5 probably wouldn't be too far off the mark.
what did the noise actually sound like? was is like a marble in a tin can? if so then that is most likely pinging, which is bad. however if it starts doing it more often in other gears and rev ranges then you may have a broken manifold stud and the sound is the gasket vibrating.
if the sound was more like it was misfiring then it's either your coils or spark plugs
Cheers mate,
Ill check it again during lunch and give a better description.
Ill also get someone to tell me the A/F ratio during high boost...I really dont want to be screwing the engine.
It may be pinging as Marc said. If so, you can top up your fuel with extra toluene (methylbenzene) just to check.
Alternatively, octane booster can be used; but 1x bottle will make little difference. 2x bottles are needed to check.
If pinging ceases, then your state of tune will need to be rectified.
thanks for the replies guys,
when driving home on some nice road it didn't really sound like marbles in a can. oddly enough the only sort of sound I can compare it to was two pieces of paper hitting each other really quickly. It also isn't a constant noise.
Ill put some octane booster in over the weekend to see if it helps.
Might also go through the engine bay to see if anything is loose.
Well I finally got one of the NVH guys at work out over lunch to listen to the chatter.
Found out that the sound of coming from the gearbox/gear stick.
When I am accelerating in 5th gear and push the gear stick up and to the left the chatter sound becomes worse but when the gear stick is pulled slightly downward it goes away.
We were thinking it may be gear boot related. Has anyone else had this issue before?
Cheers
Is it completely gone in 4th?
There are bearings (cluster bearings?) in the gearbox that can get pretty noisy in all gears except 4th (where there is no load on them)
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
