I have recently sold my car and decided that i'm not going to sell it as one with the sound system. It has costed around 6k mark and is top of range components. No expenses have been spared and as you can see below ALL items are quality brand names.
This has come out of an R33 coupe so it will be a direct factory fit and you will not be able to tell that it's an aftermarket sound system! It would have to be one of the CLEAREST sound systems you will hear.
I had the speakers running from a 4 channel and the subs from the mono block.
Amps:
Kicker KX 600.1 mono block
Amplifier Output Details:
690.0 Watt - 2.0 Ohm - THD 1.5 % - 14.4V DC - 1.0 channel(s) , 600.0 Watt - 2.0 Ohm - 13.8V DC - 1.0 channel(s)
Alpine MRP- F240 4 channel
Amplifier Type: Multi Channels
Bridgable (4 channel)
RMS Power at 4 Ohms: 40 W x 4
RMS Power at 2 Ohms: 50 W x 4
3 Way Ready
Subs:
2x 12inch in original Pioneer box
post-48038-1276787919_thumb.jpgpost-48038-1276787908_thumb.jpgpost-14128-1123124146.jpg
Capacitor:
Stinger 1 farad pro capacitor
Front Speakers:
MB QUART- made in Germany
DWE 160- 4 OHM
50-120 Watt
The tweeters have been mounted in the pods (see photos), can be easily removed if required
Rear Speakers:
Focal- made in France with tweeters
Focal 6.5 Inch Coaxial Speaker
70 RMS
Head Unit:
Pioneer DEH-P9650MP
Current the face needs to be fixed as it does not move down (quoted 120 by pioneer)
Or for an extra 200 I can include a Alpine CDA 9885
Price:
$1800 no ridiculous offers, but will consider serious ones
Guys i'm too keen on parting this out, happy to sell as 2 packages:
Speakers (both), Pinonner HU, and alpine amp $800
Subs, kicker mono and cap $800
Or as on package $1500
PRICE DROP
Guys if you want a package please deal please PM what you are after and at what price you are willing to pay. Otherwise mid way through the week i will price each bit individually.
My preference is one/ two packages simply because focal speakers need to be matched with another good brand otherwise you will find that the cheap pioneers will drain the quality out of the focals (for example). Plus while the amps don't have the highest RMS i never need to run them at max gains etc because it is not required. These amps have more than enough power to run all the speakers/ subs.
PS i'm not going to bother replying to low ballers, please be serious with what you are suggesting. As the add says, neogitable to serious customers only.
PRICE DROP $1400 for the package!
MB QUARTS/ FOCALS- $300 each for $550 the both
Alpine Amp- $300
Kicker Mon0- $500
Subs- $250
Cap- $200
Pioneer HU- $100
Alpine HU- $250
Now willing to sperate the package!
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 馃檪  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 馃槃 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
